Hand clamp rack plans
Forum topic by bluekingfisher posted 09-06-2012 11:28 AM 6515 views 0 times favorited 15 replies Add to Favorites Watch
View bluekingfisher's profile
bluekingfisher
1247 posts in 2851 days
09-06-2012 11:28 AM
Hi Guys – I’m looking to clear up more space in my workbench drawers. One of the drawers currently holds my hand clamps. I was hoping to clear the drawer but looking for good ideas on small hand (6”) clamp rack to hang on a wall or ceiling.
Can anyone recommend a plan or point me in the right direction.
Thanks, David
-- No one plans to fail, they just, just fail to plan
15 replies so far
View Belg1960's profile
Belg1960
1054 posts in 2936 days
#1 posted 09-06-2012 12:26 PM
Dave, are you talking about handscrew clamps?
-- ***Pat*** Rookie woodworker looking for an education!!!
bluekingfisher
#2 posted 09-06-2012 02:10 PM
Hi Pat, No I don’t have any of the handscrew clamps, mine are the spring clamp and ‘F’ clamp style but something as simple as what you have highlighted may be good enough.
Cheers
David
View teejk's profile
teejk
1215 posts in 2555 days
#3 posted 09-06-2012 03:22 PM
rod is 1/2” conduit (I prefer that over wood dowels due to stiffness (and cost!). wood is 1×6. the vertical slats are due solely to my interior walls where I have to fir out to get over the ribbed steel. I brought the stretchers out so I could cut a 1/4” groove at the rear to hold the smaller clamps.
Belg1960
#4 posted 09-06-2012 03:51 PM
Dave, like the last poster I use pieces of dowel or electrical conduit drilled into a piece of 1x spaced to fit the amount you have. This is a picture from wood magazine.
teejk
#5 posted 09-06-2012 06:20 PM
Belg wins! very nice! other than I know I don’t have enough clamps, perhaps you have too many? LOL
View CplSteel's profile
CplSteel
142 posts in 2035 days
#6 posted 09-06-2012 07:24 PM
I hung a 3/4” dowel and it holds everything easily enough. I drilled a hole in the end of a 7” piece of 2×4 and then ripped it in half. Ran a dowel through the holes and screwed em to the studs.
Belg1960
#7 posted 09-06-2012 07:29 PM
teejk, I admit I do have alot of clamps but the ones in the picture aren’t mine.
View ChrisK's profile
ChrisK
1865 posts in 2952 days
#8 posted 09-06-2012 07:30 PM
Part of my shop has the overhead joists exposed, I clamp a lot of my clamps there.
-- Chris K
TopamaxSurvivor
18161 posts in 3547 days
#9 posted 09-06-2012 08:28 PM
How about stringing a line or wire and just setting them over it. If the F clamps are nearly closed they won’t fall off. I do this occasionally. Keeps them handy and out of the way.
teejk
#10 posted 09-06-2012 09:00 PM
topamax…your solution will work but not very pretty! I didn’t measure the dimensions on mine (built in my head as are 99.9% of the things I do as I design around scraps like a true German will).
I did run a dado on the back board to accept the stetchers (glued and screwed)...other than that, it is pretty simple in design and it allows for expansion. The 1/2” conduit I have is probably 24” long and works for what I have. I would not be worried about taking that to 60” if I needed to. The conduit is rigid and cheap (10’ section maybe $3???). The slices in the back receive a strip of 1/4” plywood that could be expanded as well. For what I hang on there, weight is not a problem.
View Gshepherd's profile
Gshepherd
1727 posts in 2072 days
#11 posted 09-06-2012 09:52 PM
I just took some 3/4 pipe about 18” long and use a pipe flange and screwed it into the wall to hang mine. Easy and if they need to be moved elsewhere later it is quick to do so.
-- What we do in life will Echo through Eternity........
View Grandpa's profile
Grandpa
3259 posts in 2546 days
#12 posted 09-06-2012 10:03 PM
I bought some already made hooks that are designed and sold for hanging ladders. I got them for a couple of dollars. They work great.
View tenontim's profile
tenontim
2131 posts in 3615 days
#13 posted 09-06-2012 11:07 PM
This is how I do it. These are mounted to the underside of the stairs, but a similar shaped support could be used in the same way
TopamaxSurvivor
#14 posted 09-07-2012 12:50 AM
Maybe not pretty, but sure is handy ;-)) pull the line tight and they are up out of the way. A little slack and they are all right there where you need them.
bluekingfisher
#15 posted 09-07-2012 07:24 AM
Teejk, Pat, Cplsteel, ChrisK, Bob, Gshepard, Grandpa, Tenontim – Thanks fellahs for taking the time to offer your ideas.
I was having a think about it overnight (as you do) I have limited walll space, due to existing and futre plans for the walls. However I have the side of my bench/outfeed table free and not gainfully employed. The gap between the side of the bench and the back of my tS is about 14”. In my world that is a lot. I had planned to hang my cross cut sled in there. It being underneath the bench and behind the saw I was going to install a couple of drawer slides, screw a sheet of ply to ithem so that it is now a kind of vertical drawer bottom, then hang/fix the cross cut sled to that. That way all I need to do is slide it in and out of the way when required.
While thinking about this I was wondering about using the back of the board that the sled will ride on. If I add a couple of 2×4 braces then mount the runners on those that should give me 4” or so from the side of the bench to the back of the sled drawer baase ( I hope I’m making sense of this)
The only other place to hang them is above my bench or TS, neither of which appeals to me. I have the feeling they are likely to fall off and clump me on the nut, or worse onto my TS.
I have about a dozen or so of this size clamp so I may be able to get them all on there. The ones I can’t find space for may have to find a new home
Thanks for the input fellahs, some great ideas there.
Cheers
David
