Planing to even thickness
Forum topic by Slacker posted 126 days ago 216 views 0 times favorited 6 replies Add to Favorites
View Slacker's profile
Slacker
174 posts in 238 days
126 days ago
I recently posted something about resawing with a table saw. I followed the advice that some of you kindly shared with me, and I am feeling more comfortable about using the table saw for resawing. Just to be sure that I will be playing guitar for many years, I got me the GRR gripper to push wood into the blade.
I was also shopping for a thickness planer, and instead got me a handplane ($10 at Lowes) which works like a charm. So I was wondering if anyone knew of a jig I could build to plane a piece of resawn wood to the same thickness throughout.
-- There are three kinds of people... those who can count, and those who can't
View tenontim's profile
tenontim
960 posts in 281 days
126 days ago
If you’re going to be a Neanderthal, then you have to do the whole thing the old way. Once you get one side flat, use a marking gauge and layout your other side all around. Then take that new plane and a straight edge and go to work. It’s more fun than you think.
-- Tim -- http://tmuli.com
View Loren's profile
248 posts in 185 days
125 days ago
The correct jig is a flat bench.
Handplanes will naturally tend to produce uniformly
thick panels if you use a truly flat workbench. I am
not saying you don’t have to pay attention to what
you are doing, but the plane will cut off the high spots
first. As long as the pressure of your weight isn’t forcing
the board into concavities on the workbench top you
should be able to produce relatively uniform panels
by eyeballing the thickness. A marking gage helps to get
the thickness very correct all the way around.
I’ve found it actually more challenging to thickness
smaller boards than larger panels with handplanes.
Thicknessing by hand is sweaty work but enjoyable if you
don’t do woodworking to pay the bills.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online businesses - http://COPYMATCH.COM
View marcb's profile
marcb
199 posts in 210 days
125 days ago
Two words
Jointer Plane
I recently picked up a No. 6 clone to go along with my No 7 nice for shorter boards
View Keith Cruickshank's profile
Keith Cruickshank
36 posts in 181 days
125 days ago
Good advice so far. I especially like Loren’s thought on getting and using a good workbench. That really is the key to using a hand plane. The plane’s natural partner is a well- made, solid, flat bench. In some cases, you don’t even need a vice. Simply a bench stop on one end of the board is sufficient.
Time is all you need – and some skill. You can use a marking gauge to thickness plane, but remember, you have to have one very flat side first to reference to. If there is twist it must be removed. I have a short video that explains some of the basics including how to remove twist/warp that might be useful at: http://woodtreks.com/how-to-use-a-hand-plane/21/. Hope that helps. Keith (www.woodtreks.com)
-- Keith Cruickshank, www.woodtreks.com
Slacker
125 days ago
Nice video, Keith… I am just making boxes, fine tuning my long-lost skills in preparation for a new career in the Island where I’m form.
When resawing with a table saw, I have found that a small divet forms where the cuts on one edge meet those on the other, so I generally cut 1/32” larger than the width I am targetting. After I got that cheap plane at the big blue box store, I found that this was a lot easier done with a plane than by sanding.
I suppose you could say that using hand tools prepares you to become a better woodworker, because if you find yourself in a situation with no power tools, you can still do your thing.
marcb
125 days ago
Sometimes hand tools just fit the need better than power tools. The finish left by a good finishing plane is far superior than sanding. Even if I sand I like to scrape after to get the sharp distinct look rather than the slightly fuzzy look after sanding.
Theres guys out there who combine the power/hand tool worlds very well. And it sounds like you found a way to do this in your shop.
Bookmark And Share This Page
