Motor RPM for Jointer
« back to LumberJocks.com Site Feedback forum
Forum topic by greatgates2340 posted 258 days ago 718 views 0 times favorited 12 replies Add to Favorites Watch
View greatgates2340's profile
greatgates2340
1 post in 403 days
258 days ago
I have a four inch jointer from the fifties. it came without a motor. The specifications call for a 1/3 HP, 1725RPM motor. I have a 3450RPM motor. How can I cut the RPMs down to the 1725? Friends have suggested putting a pulley on the motor that is twice the size of the one on the jointer…will this work?
12 replies so far
View ssnvet's profile
ssnvet
1557 posts in 497 days
#1 posted 258 days ago
To slow the motor down, put the small pully on the motor and the large pully on the jointer shaft…. then it will take two revolutions of the motor shaft to turn the jointer shaft once.
That said… the physical layout may preclude getting a large enough pully mounted on the jointer.
-- Matt, Pine is fine, but Oak's no joke!
View mtenterprises's profile
mtenterprises
623 posts in 862 days
#2 posted 258 days ago
Is this an AMT jointer? If so I have the correct size pulleys and motor on mine and can give you the proper cutter head rpm. (after I go check it)
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View MNgary's profile
MNgary
215 posts in 586 days
#3 posted 258 days ago
When you find the correct pulley sizes called for in the original design, reduce circumference of the motor pulley to one-half the original spec. Note that it’s circumference, NOT DIAMETER.
-- "I dream of a world where a chicken can cross the road and no one questions its motive"' - Anne Nonny Mouse
mtenterprises
#4 posted 257 days ago
Ok, on my AMT jointer with orignal pulleys and a 1/3 hp 1725 rpm motor, the motor pulley is 4” and the cutter head pulley is 2” which will make the cutter head run at half motor speed which is 862.5 rpm. I could use a 3450 rpm motor for another project. Want to trade?
MIKE
View shampeon's profile
shampeon
517 posts in 352 days
#5 posted 257 days ago
What you want to do is figure out the cuts per minute (CPM) for your cutter head, and get pulleys to match your motor. For example, my old King-Seeley Craftsman jointer specified 11,000 CPM, so I used a 4” pulley on my 1725 RPM motor, and a 2” pulley on the 3 blade cutter head.
Use the OWWM calculator here:
http://vintagemachinery.org/math/cpm.aspx
There’s no reason why you couldn’t use a motor with more horsepower (to a point), so if you wanted to find a 1725 RPM 1/2 or 3/4 HP motor you’d probably have less trouble face jointing.
View Loren's profile
4883 posts in 1817 days
#6 posted 257 days ago
12-15000 cuts per minute is a good speed for jointing,
so if your cutterhead has 3 knives, you want about 5000 rpms
on the cutterhead.
Those specs are BS. You’ll get better jointer performance
running a 3450rpm motor. If the cutterhead pulley is 2”
then a 4” pulley on a 3450 motor gets the cutterhead
moving fast enough for clean jointing.
Just my opinion, understand. I’ve set up a lot of jointers
with motors over the years.
With a 1725 rpm motor you need a 7” or 8” pulley. I know
because I have such a big old motor in my yard I pulled off
a jointer and I cannot get the big pulley off the shaft. I
was going to throw the motor away (big old repulsion
motor) but desire to possess the pulley stayed my hand.
shampeon
#7 posted 256 days ago
A 4” pulley on a 3450 RPM motor with a 2” pulley on a 3 blade cutterhead makes 20,700 CPM. That may be above the spec of the bearings.
A 2.5” pulley on the motor works out to a little over 12,000 CPM.
View JimmyJam's profile
JimmyJam
31 posts in 648 days
#8 posted 256 days ago
MNGary – If you reduce the diameter by half you automatically reduce the circumference by half as the circumference = Pi * Diameter.
mtenterprises
#9 posted 256 days ago
If this is as I asked “is this an AMT Jointer?” No the bearings will not take that rpm because they are bronze bushings. Guys remember greatgates2340 has a four inch jointer from the fifties, this is a CHEAPY, I know I have one and 850 +/- rpm is about all it will take. Yes the more Cuts Per Inch you can make the better but not at the expense of the machine. This is like an under $50 machine it’s not a Dewalt from the same time period. In this case it is easier to go to the flea market and pick up the correct motor 1/3 hp 1725 rpm off from a furnace blower for $15 than to futs around trying to slow down a 3450 rpm motor. Man in my neighborhood you can find a blower out for the trash and the motor is usually good.
MIKE
MNgary
#10 posted 255 days ago
Good point, JimmyJam.
shampeon
#11 posted 255 days ago
If it has bronze bearings, you definitely don’t want to go over spec on the CPM. But I don’t think the OP has stated what model his/her jointer is, and I think by the ‘50s most jointers were using ball bearings.
mtenterprises
#12 posted 255 days ago
Personally guys I think we’re just debating amonst ourselves greatgates2340 hasn’t chimed in since this was written.
MIKE
