Free UHMW Plastic
Forum topic by lew posted 07-29-2008 02:27 AM 4245 views 2 times favorited 18 replies Add to Favorites Watch
View lew's profile
lew
12262 posts in 3870 days
07-29-2008 02:27 AM
Topic tags/keywords: jig uhmw glue free
I have found a free source of a type of UHMW plastic. It works great for work surfaces- especially a gluing surface. It can be cut and worked with all standard tools. The only draw back is that the surface is not completely smooth. To get the free stuff, just make friends with a local restaurant owner (not a fast food place). Here in Pennsylvania, the health inspectors require stained plastic/gouged cutting boards be removed from service and discarded. The owners just throw them in the trash!
They can be found in various sizes and are around 1/2” thick
Pieces work great between clamps and glue joints because many glues do not stick to the plastic.
18 replies so far
View steveosshop's profile
steveosshop
230 posts in 3741 days
#1 posted 07-29-2008 02:51 AM
Thanx for the tip lew. I will have to find some local resturants and ask around.
-- Steve-o
View fredf's profile
fredf
495 posts in 3825 days
#2 posted 07-29-2008 03:28 AM
wonder if you could run through the thickness planer to clean them up?
-- Fred, Springfield, Ma
View Chris 's profile
Chris
1879 posts in 4106 days
#3 posted 07-29-2008 03:43 AM
Would it melt in the Planer though?
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View lew's profile
lew
#4 posted 07-29-2008 04:08 AM
I have never tried the planer. When you cut it with an 80 tooth 10” blade, it makes “saw dust” just like wood.
View lew's profile
lew
#5 posted 07-29-2008 04:12 AM
Just found this:
http://www.redwoodplastics.com/index.php?content=uhmwfabricationguidelines
http://www.plasticsmag.com/features.asp?fIssue=Sep/Oct-03&aid=3862
Lew
View tenontim's profile
tenontim
2131 posts in 3859 days
#6 posted 07-29-2008 04:47 AM
This is great. Should be able to start a whole new strain of furniture borne salmonella viruses. :]
View ENelson's profile
ENelson
1 post in 3704 days
#7 posted 07-29-2008 03:02 PM
Not free, but you can also buy directly from a UHMW manufacturer—Garland Manufacturing
They also have a FAQ that tells how to mill it or plane it.
Also, Onsrud Cutter has a FAQ with the recommended bits and mills
View motthunter's profile
motthunter
2141 posts in 3914 days
#8 posted 07-29-2008 09:07 PM
great tip.. thanks
-- making sawdust....
View lew's profile
lew
#9 posted 07-29-2008 09:16 PM
rick,
You are probably right.
I did not actually research the plastic type but assumed (and you know what that does) because of its weight, cutting characteristics and general appearance that it was UHMW.
Sorry if I caused anyone any problems!
Lew
View Sac's profile
Sac
268 posts in 3749 days
#10 posted 07-30-2008 01:19 PM
Nice tip Lew. I’ll be dropping by the local family owned business’s and asking about them.
-- Jerry
View palaswood's profile
palaswood
1055 posts in 1866 days
#11 posted 11-07-2013 06:38 PM
I came across this stuff when seeing it advertised as the guide surface for the veritas dovetail guide. Its smooth and durable and I could use some for making my own dovetail saw guide. Thanks for the tip!
-- Joseph, Irvine CA, @palas_woodcraft on Instagram
View 69BBNova's profile
69BBNova
341 posts in 2332 days
#12 posted 11-07-2013 07:22 PM
I’ve never heard of UHMW is it plastic?
All I hear in my head is—-ultra high molecular weight…
To lazy to read about it yet.
Just saw the title. plastic, never mind
View ratchet's profile
ratchet
1391 posts in 3902 days
#13 posted 11-07-2013 07:24 PM
Use a card scraper on them and they will clean up nicely!
View lew's profile
lew
#14 posted 11-07-2013 07:45 PM
Yes, it is a type of plastic. Very dense and very slippery.
View Tony Strupulis's profile
Tony Strupulis
260 posts in 3238 days
#15 posted 11-08-2013 06:44 AM
It goes through the planer just fine. I thinned some down in order to make zero clearance insert plates out of it.
-- Tony - http://ravensedgetoolworks.com
