Bench Bandsaw Problems
Forum topic by Kasm posted 09-05-2012 05:34 PM 2171 views 0 times favorited 7 replies Add to Favorites Watch
View Kasm's profile
Kasm
7 posts in 3015 days
09-05-2012 05:34 PM
I bought a Skill benchtop bandsaw. It is 9” with 1/3HP.
I have had problem with it since I bought it. It stalls all the time, even when cutting thin materials (< 1”).
I have to feed the wood extremely slowy to be able to cut anything. I started thinking, this bandsaw was underpowered and I needed a bigger one. But I am noticing the big bandsaw capable of resaw >7” still have less than 1 HP.
Does a bandsaw blade wear out that fast? I haven’t used my bandsaw for much work. How thick of a piece of wood should I except to be able to cut with a 1/3 HP band saw and what type of feed rates?
7 replies so far
View HorizontalMike's profile
HorizontalMike
7770 posts in 3147 days
#1 posted 09-05-2012 05:42 PM
You have hit upon a number of things to check on and be aware of… blade sharpness, material thickness, and feeding speed. While my BS is a larger 14”, I would think that you are probably very near to the design maximum in what you are asking your 9” machine to do. I would suggest slowing your feed and checking your blade’s sharpness and number of TPI for starters.
View AJswoodshop's profile
AJswoodshop
1057 posts in 2510 days
#2 posted 09-05-2012 05:47 PM
My old bandsaw does that all of the time. Bench top bandsaw’s have a lot of issues. The can’t cut on your line, that’s the big problem. I would never buy a bench bandsaw, I had a bench bandsaw once. It would not cut strait either, I recently got a 1936 bandsaw, and it cuts better. So I would just save up for a really nice band saw.
AJ
View Surfside's profile
Surfside
3389 posts in 2407 days
#3 posted 09-05-2012 06:37 PM
The problem lies on the quality of the blade and the blade speed that you’re running your saw. Change blades and run your saw faster.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View Fishinbo's profile
Fishinbo
11362 posts in 2409 days
#4 posted 09-05-2012 08:37 PM
http://lumberjocks.com/topics/19665 This thread might help you regarding bench-top band saws.
Best of luck.
View Towtruck's profile
Towtruck
70 posts in 2842 days
#5 posted 09-05-2012 09:17 PM
I bought an old 9” Toolcraft bandsaw several months ago. After replacing both tires and the bushing in the top wheel, along with a new 1/4” 8 tpi blade it’s just like having a new saw. A little noisy but very smooth. I’ve been using it mostly on 1” and 5/4, the 1/4 horse motor acts like it’s loafing, no effort at all.
I think this saw might be one of the few tools I ever bought that I got more than I expected for the price I paid.
If your saw motor actually stalls, I might guess that’s it geared to high.
-- I cut it off 3 times and it's still too short!
View woodklutz's profile
woodklutz
221 posts in 3002 days
#6 posted 09-05-2012 09:34 PM
I had a similar problem and just by tightening the drive belt it made all the difference. On my jet I just moved the motor mount back to tension. If that is not the cause of your problem, then a better blade say 1/4×6tpi.
Nothing more frustrating than a tool that won’t work right, fortunately most problems are fixable without spending a lt.
You can look at my post on a supplier for blades, economical great product and service.
-- honing my craft one mistake at a time.
Surfside
#7 posted 09-06-2012 02:15 PM
Just look at my signature and you’ll find a good supplier for quality blades!
