| Forum topic by NEwtoowood | posted 259 days ago | 746 views | 0 times favorited | 13 replies | ![]() |
259 days ago |
Topic tags/keywords: table joining Help, I am new to furniture building and have limited tools. I am trying to build a dinning room table out of 4/4 ash various widths about 7 ’ long. I have a table saw and biscutjoiner. The wood has been plained but the edges need to be straightened up. The problem is my saw is not up to the task , the rips are not going well and the edges look no better than the what was there. Any ideas? I am not looking for perfection but I do want it to look decent. Any help is appreciated. |
13 replies so far
#1 posted 259 days ago |
Do you have a router table? You can offset one side with a flush bit and use a jointer. -- Dont just dream it, get up and live it! |
#2 posted 259 days ago |
I’ve had to do something like this before and ended up with decent results. Hopefully I can put it into words.. Table Saw Joining I saw a video on it once, cannot find it now unfortunately, but it has worked for me. Hand Plane Lather, rinse, repeat. -- Grant - S/N Dakota |
#3 posted 259 days ago |
If you want to use your table saw, get a piece of mdf or plywood with a factory edge and rip it on your saw. Then attach one of your planks to the board (double sided tape) and run the other edge of the mdf against your fence. This should produce a good edge on one side of the plank. Flip it and reposition the fence to dress the other edge. -- "Measure twice, cut once, count fingers" |
#4 posted 259 days ago |
I’ve had to do something like this before and ended up with decent results. Hopefully I can put it into words.. Table Saw Joining I saw a video on it once, cannot find it now unfortunately, but it has worked for me. Hand Plane Lather, rinse, repeat. (I edited this and for some reason it posted twice, sorry) -- Grant - S/N Dakota |
#5 posted 259 days ago |
I don’t have a jointer, so I use the tablesaw method (described above), all the time. But stick the MDF to the good wood using 3” strips of double-sided tape, about every foot. You don’t need to screw the boards together. The double-stick tape (carpet tape) is plenty strong enough. In fact, right after you cut, separate the boards and get that sticky stuff off your good wood! Much harder (for me) is getting a nice flat glue joint. The longer the joint, the more fussiness required. Clamping, over and under, with cauls (very slightly curved boards) seems to help – along with clamping across the glued edges, of course. Still, there’s always a bit of cleanup necessary from squeeze-out and slight mis-alignments. A hand jointer (#7) or scraper or even sandpaper works well. The more careful you are, the less cleanup. -- Jim Maher, Illinois |
#6 posted 259 days ago |
From your description, it sounds to me like the blade is your problem. Any properly-set-up table saw with a good blade should be able to rip an edge suitable for glue up on 4/4 lumber. What type of blade are you using, and do you know if it is sharp? A photo of the ripped edge of the board would be very useful in diagnosing the problem. -- Charlie M. "Woodworking - patience = firewood" |
#7 posted 259 days ago |
If you just can’t get it done with the advice above for a tablesaw and if you have access to a router (and suitable bits), there are some other options as well. Option 1: Using a flush cut bit you and the machined side of an MDF sheet, you can make a flat edge by clamping the two together and recessing the MDF enough to remove the necessary material to flatting the ash. Option 1a: You could do a similar edge with just a straight-cut bit and moving the MDF back far enough so the bit can pass along the edge needing flattening. Option 2: Here is a technique to edge joint boards to each other. Lay your table top out as you would assemble it. Separate the boards from each other 1/8” or less. Clamp them down to your work surface. Use the above methods (MDF sheet plus router) to position a 1/4” bit so it cuts both boards simultaneously. Any deflections or waviness will show up on both boards but have them matched to each other. With ash, I’m thinking this may take a while depending on the power of your router and the cutting edge of the bit. Hopefully what I just said makes sense. I’m sick and on meds. LOL Option 3: Last but not least, as Grant said, get a #7 or #8 Stanley jointer and get it done. You can buy those for under $100. Heck, you might even be able to score an old jointer on craigslist for not much more (if you have the funds and room). -- "Well, at least we can still use it as firewood... maybe." - Doss |
#8 posted 259 days ago |
CharlieM, here are 4 pics of the rip cut and blade. When I was cutting this I needed to push more than I wanted , causing the board to move a bit. It was tough to keep it going in straight. I do not know what type of blade it is as it came with the saw. Thanks I appreciate your help |
#9 posted 259 days ago |
Grant, I am not sure I understand. |
#10 posted 259 days ago |
NEwtoowood, 1. I think the part that wasn’t made clear is that the MDF is making contact with the fence and not the tabletop board itself. The MDF provides a straight reference point for the blade (if the blade and fence are parallel of course). 2. To make the other side parallel, you remove the MDF and then reference the newly cut, straight edge on your tabletop board by allowing it to now make contact with the fence. -- "Well, at least we can still use it as firewood... maybe." - Doss |
#11 posted 259 days ago |
As Doss said NEwtoowood. Sorry for the confusion. The reason you run the MDF against it and not your board is that the MDF’s manufactured edge is usually a true straight edge. If that is what you are trying to achieve on your board I assume that your edge is not perfect and while running this “not perfect” edge against the fence it will leave you with a similar edge to the one that you ran along the fence to begin with. Also I feel that this method lets you keep more stock and scraping less of it. -- Grant - S/N Dakota |
#12 posted 259 days ago |
NEwtowood, the advice some of these guys are giving you is for cutting a straight reference edge on a board that has two wavy edges. I don’t think that is the issue here. You’re just talking about the quality of the cut. Using the MDF straight edge method is not going to improve your cut. I’m still leaning towards one (or a combination of) these: 1. dull blade -- Charlie M. "Woodworking - patience = firewood" |
#13 posted 259 days ago |
Or you are having a tough time keeping the wood moving without angling it one way or another while you feed it into your blade. Featherboards will help you keep the feed straight during long rip cuts like this. These are also great safety devices. Do you have anything on the outfeed side of the tablesaw or just the back of the table itself? You dont want to be gripping that board for dear life to keep ot from teeter tottering on ya, so some “deadman” roller stand would help http://lumberjocks.com/toddc/blog/12006 – roller stand http://lumberjocks.com/Gord/blog/2080 – featherboard blog -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15786 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
