Cutting angled pieces
Forum topic by JTTHECLOCKMAN posted 09-05-2012 01:40 AM 1458 views 0 times favorited 6 replies Add to Favorites Watch
View JTTHECLOCKMAN's profile
JTTHECLOCKMAN
232 posts in 3388 days
09-05-2012 01:40 AM
Not really staves but I am looking for a safe and true way of cutting pieces about 8 to 10” long on a tablesaw. I want to be able to use either 4 or 6 or 8 pieces to make a cylinder. So what I am looking to do is cut lengths of wood with both sides with the appropriate angles. Not sure what they call these but they would look like a stave but not a compound angle. Anyone have suggestions for a safe easy accurrate method??? Thanks
-- John T.
View Loren's profile
10477 posts in 3886 days
#1 posted 09-05-2012 01:43 AM
If they aren’t tapered ripping them is not less safe than ripping
90 degree edges on the table saw. I would just use a fence
and a push stick. You can use featherboards too.
View mikethetermite's profile
mikethetermite
599 posts in 3504 days
#2 posted 09-05-2012 02:55 AM
http://www.woodworkersjournal.com/resource/GluingTechniques/Stave/index.html
Try this to see if this is what you are looking for.
-- Mike The Termite ~~~~~ Working safely may get old, but so do those who practice it.
View OnlyJustME's profile
OnlyJustME
1562 posts in 2615 days
#3 posted 09-05-2012 05:30 AM
I believe there are also router bits that will perform this function.
Found one version of it.
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_door.html#multisided_glue_anchor
-- In the end, when your life flashes before your eyes, will you like what you see?
JTTHECLOCKMAN
#4 posted 09-06-2012 11:07 PM
Thanks Mike. That works. Gives me the idea of what to do.
-- John T.
View Woodknack's profile
Woodknack
12465 posts in 2618 days
#5 posted 09-07-2012 07:17 AM
Looks like your question is answered but you might find this interesting.
http://woodgears.ca/miter/index.html
View oldnovice's profile
oldnovice
7380 posts in 3606 days
#6 posted 09-07-2012 07:58 AM
I try not to change the angle on my TS as it is old and difficult to get back to perpendicular so I use a router bit in my RT and get much better results.
I use one bit quite a lot it id 11.25 degrees (Eagle America #152-1105 = 11-1/4° x 1”) and I would have a hard time setting my TS to that accuracy … not that I am going to get that precise and angle on long stock but I don’t have to worry about compounding the error with a bad angle on my TS.
Eagle Angle bits a link to their angle sets
