Gap in glued joint
Forum topic by sphayden posted 09-05-2012 01:31 AM 2208 views 0 times favorited 22 replies Add to Favorites Watch
View sphayden's profile
sphayden
38 posts in 2191 days
09-05-2012 01:31 AM
Topic tags/keywords: glue joint
When the glue-up of my bed footboard dried I saw that the backside on one corner did not close and left about 1/8” gap in that area. Should I / Can I fill it with something?
22 replies so far
View derosa's profile
derosa
1572 posts in 2738 days
#1 posted 09-05-2012 01:50 AM
Take sawdust from the same wood if possible, might have to saw up scrap and mix it with glue to fill in the gap. If possible you could also try ripping the joint on the table saw and gluing it up if you just have one solid glue up.
-- --Rev. Russ in NY-- A posse ad esse
View waho6o9's profile (online now)
waho6o9
8098 posts in 2479 days
#2 posted 09-05-2012 01:53 AM
+1 for Derosa on the sawdust and glue blend.
View HorizontalMike's profile
HorizontalMike
7747 posts in 2816 days
#3 posted 09-05-2012 01:58 AM
I think either of Russ’ suggestion will work depending on the severity of the crack:
  • Is the crack so bad as to be a structural problem?—Rip & re-glue
  • Is the crack purely cosmetic?—Fill
You will have to decide just how bad that crack/separation is.
View Grandpa's profile
Grandpa
3259 posts in 2578 days
#4 posted 09-05-2012 02:23 AM
The glue and sawdust will not stain like the wood so if the gap is in a place where it will be seen then you might consider that. If I could I would rip it and gl;ue it again. Did you use a jointer to true the edges and did you make certain you kept the wood against the fence on the jointer? Just brainstorming.
HorizontalMike
#5 posted 09-05-2012 02:29 AM
If you go the rip&glue route, then using either a biscuit or floating tenon would be best, if you have that ability/equipment. Or even a couple of dowels.
116900 posts in 3479 days
#6 posted 09-05-2012 02:35 AM
If you feel you joint is solid and you have no structural problems,then I would use a small piece of the same wood with the grain running the same direction and glue it in place. If you can avoid getting glue on the out side of your shim the stain will match much better.
sphayden
#7 posted 09-06-2012 02:28 AM
Thanks for the ideas. This is a picture of the gap. It is on the footboard cap. One side is flush, but the other did not sit flush when I glued it. Maybe I could carve out some of the glue in the area that is not flush and pull it back down with a clamp.
View AandCstyle's profile
AandCstyle
2977 posts in 2159 days
#8 posted 09-06-2012 02:37 AM
You might be able to saw out the excess wood/glue with a flush cut saw. Then pull it down with a clamp and hold it in place with a couple “decorative” dowel pins of the same or contrasting wood. Of course, you will need to add the pins to the other 3 posts as well. HTH
-- Art
#9 posted 09-06-2012 02:39 AM
Now that I see a photo my earlier idea would not work.depending on you joinery,you can try too force it up and risk breaking the leg or the cap or you can saw the cap off by cutting the joinery between the leg and the cap or just plan on making a new cap and saw down the middle of the cap and make a new one. If the corners were not round you could have added some trim all the way around the leg and hide the crack.
derosa
#10 posted 09-06-2012 02:45 AM
For something like that I would make a sled that would hold the footboard perpendicular to the saw blade and rip the top off. Try to get a nice clean cut on the top of the footboard, you shouldn’t need to worry about height so the loss of the footboard is best and will give a clean flat surface to reglue, and either clean the bottom of your current top piece though the planer or make a new one. If you rip through the footboard then you’ll be able to just clean the top piece and not lose any real thickness there.
edit:
Relooking at the pic it appears that the post is angled at the top, the back edge has the surface flat while the front edge doesn’t and the rail appears mostly flat but maybe that post back edge isn’t quite flush and pushes the top piece up very slightly as it appears there is a tiny gap that forms under the cap towards the post. Someone below mentions trim and that may be the quickest, easiest and maybe prettier solution. If not definitely rip the top off on the saw for one straight edge all the way across to get the new top to sit the same the whole way. Although clamps shouldn’t be used to force a piece into place I now have a policy of waiting very close to the full 24 hours to make sure that what may be a slightly less then perfect fits stays put.
waho6o9
#11 posted 09-06-2012 02:47 AM
Put a decorative trim around the perimeter.
View Prplhrtjarhead's profile
Prplhrtjarhead
80 posts in 2008 days
#12 posted 09-06-2012 03:10 AM
Like someone else mentioned, just brainstorming…but it looks to me like a glue up problem.
Were your clamps straight and centered during the initial glue up?
Might not be necessary these days, but I always alternate my clamps when gluing up, one on the front side, then the back, repeating the whole length of a piece. Like I said, maybe that’s old fashioned or out of favor with the better glues/clamps available these days. But it is how I learned and it has never failed me.
Not trying or intending to insult; though sawing, joinery and other processes may be the culprit, clamping can be just as big an issue, and an often overlooked one. Uneven pressure can cause just this type of separation.
Good to get ideas to fix it, but better to understand all the possible causes too.
Good luck on an otherwise nice looking piece from what can be seen.
-- "We'll preserve for our children this, the last best hope of man on earth, or we'll sentence them to take the last step into a thousand years of darkness." R. Reagan, "The Speech", 1964
Grandpa
#13 posted 09-06-2012 04:13 AM
This is a tough job. Thanks for the photos. I still think I would try to cut it and either reglue or make new parts to join. Anything less will be a patch. Ask yourself how happy you will be in a year or 5 years if you leave this less than perfect or less than the best you are capable of doing. As mentioned above you need to analyze this and try to not let it happen again. You had a nice project going. Like Derosa suggested a sled might be used to hold the piece straight and secure for cutting. It will be difficult to hold this straight.
HorizontalMike
#14 posted 09-06-2012 06:17 PM
@AandCstyle said: You might be able to saw out the excess wood/glue with a flush cut saw. Then pull it down with a clamp and hold it in place with a couple “decorative” dowel pins of the same or contrasting wood.
I think you may be on to something here. This would add some meat to a weakened butt joint (once you have flushcut the top piece free). I would use a large dowel size, drill down through both top and leg after the butt joint has dried, drive a glue covered dowel and a cap of your choice of knob or finial. This way you can make look like it was planned that way from the beginning.
ETC.
AandCstyle
#15 posted 09-07-2012 01:49 AM
A refinement would be to countersink a couple screws to hold it in place, then put plugs over the screws. I think this would hold better than a dowel.
-- Art
