Table saw alignment
Forum topic by niki posted 126 days ago 652 views 9 times favorited 21 replies Add to Favorites
View niki's profile
niki
393 posts in 616 days
126 days ago
Good day
I would like to share with you my way of aligning the table saw.
As you’ll see, I’m not using any Hi-Tech nor Lo-Tech instruments because every blade has some “Run-out” and flatter.
But, I also don’t need any instruments because….the blade is “talking” to me and “telling” me if it is aligned to the miter slot or not…and who knows better than the blade….
The “Test Piece” should be of MDF but plywood will also do
Tooooo the pics….............
Regards
niki
View SteveKorz's profile
SteveKorz
1419 posts in 251 days
126 days ago
Thanks Niki!! As usual, very informative. I eat up your posts, keep’em coming!
I’m always learning….....
—Steve
-- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17)
View lew's profile
lew
1751 posts in 292 days
126 days ago
I really like your “feather board”! How do you lock it down?
Lew
View niki's profile
niki
125 days ago
Thank you for your kind words Steve and Lew
Lew
The “featherboard” is held by hand…
It has a dowel that fits the miter slot and serves as a pivot point…
The black pad is from a mouse pad…..to make the featherboard a little bit Hi-Tech :-)
I just swivel it clockwise to press on the workpiece…
as you can see, my left hand stays all the time around the miter slot…
I use it mainly with short boards that I can feed with my right hand/push block while my left hand stays on the table top.
Regards
niki
View alanealane's profile
alanealane
153 posts in 427 days
125 days ago
Your Genius mind is clear for all to see!!! Keep it up. It’s the low-IQ guys like me that need help from gentlemen like you.
You always come up with things I never thought of !! WOW
-- Lane Custom Guitars and Basses
View niki's profile
niki
125 days ago
Thank you Lane
I don’t think that you have “low IQ”...you just have less experience than me…
Looking at your “Resume” I’m 3 time bigger (well, to be true – older) and I believe that when you’ll come to my age, you’ll know much more than I do.
Best Regards
niki
View jeanmarc's profile
jeanmarc
1753 posts in 253 days
121 days ago
Your Genius
-- jeanmarc manosque france
View Chris 's profile
Chris
1259 posts in 528 days
121 days ago
Very nice Niki.. I especially appreciate your methods of work that keep your hands clear of the blade.
-- Chris
View niki's profile
niki
120 days ago
Thank you so much
Jeanmarc
If I was a genius, I would be working at least in the “Silicon Valley” and not in my small garage in some unknown small town in Poland :-)....
Chris
At the age of 63+, every finger is very important :-) so I do everything to keep them away from “slicing tools”...
Regards
niki
jeanmarc
120 days ago
I think qu’ one should not work has silicone valley to have ideas .je finds that C is very an good idea which you made. the photographs and the explanations are brilliant.
View UncleBen's profile
UncleBen
35 posts in 489 days
118 days ago
That pivoting featherboard is one of the smartest things I’ve seen, but seems so simple once you know about it. I especially like that you don’t have to clamp it down and it’s so quick to use and “set”. I’ll be making one of those shortly.
View Napaman's profile
Napaman
2092 posts in 614 days
118 days ago
thanks niki!!! your instructions are always sooooo clear and informative…I am putting this in my fav’s!!!
-- Matt, Napa, CA...119 days to sanity...
View gusthehonky's profile
gusthehonky
118 posts in 279 days
118 days ago
Great post! Respectfully speaking, I knew all that stuff, but you were able to explain it, kinda like Newton didn’t invent gravity, but was able to logically explain its abilities and limitations. Great teachers have abilities to promote and develop their students unconscious knowledge pool. Hopefully my praise will not be mistaken for malice, my prose has deteriorated since Wrt, 101. Thanks again.
-- Ciao, gth.
View niki's profile
niki
118 days ago
Than you so much for your kind words
Gusthehonky
I don’t think that I “invented” it, probably, I’ve seen bits and pieces here and there and I just connected everything together…
Here are a few more pics of the “featherboard” that I hope will make it easier for you to make it.
As a base, I used 1½” thick wood.
The wheel carrier is made of 5/16” “floor panel” screwd to the base.
The wheel is 2” diameter and 1¼” thick, cut with Hole Saw on the drill press.
To get the wheel totaly round and square, I pushed bolt, tight with nut and chucked it in the drill press and whill turning, I sanded it with sanding block…like this (from another post).
Drill a larger hole for the bolt head and washer to sink in
Finger tight the nut so the wheel can turn free
Add washers as required so the wheel will be a little bit above the table
While holding the lower nut, tight the upper nut
I made a red line just before the blade front teeth…I always keep the wheel center before the line
Regards
niki
View flink's profile
flink
95 posts in 257 days
111 days ago
Niki,
Very, very ingenious!
-- Made lots of sawdust and pounded some nails. Haven't finished anything, though.
View RAH's profile
RAH
325 posts in 414 days
111 days ago
Thanks again for the learning experience, let me know if the house next door to yours is for sale I could watch you all day.
Thanks Ron
-- Ron Central, CA
View niki's profile
niki
111 days ago
Thank you so much
Ron
They do built some houses around here but, I think that you would not like the language… :-) (me neither…)
If you would come today, you would see me digging holes and planting some trees for my wife…...part of the “points” that I’m collecting to buy new tool :-)
Regards
niki
6716 posts in 388 days
111 days ago
Great blog Niki, thanks.
View Richforever's profile
Richforever
171 posts in 257 days
98 days ago
Thanks for the wonderful ideas!
-- Rich, Seattle, WA
View RockDoggy's profile
RockDoggy
5 posts in 81 days
78 days ago
Love the ideas Niki. An instant favorite for this thread!
-- -Chris http://rockdoggy.com
View niki's profile
niki
78 days ago
Thank you all for your kind word
It gives me a good feeling that you like the idea
Best Regards
niki
View rikkor's profile
rikkor
8558 posts in 411 days
78 days ago
I try not to miss any of your threads, Niki. You always have something valuable for others to learn something. Please keep it coming.
-- Maplewood, MN
Bookmark And Share This Page
