Problem with a belt sander
Forum topic by MrRon posted 09-04-2012 07:35 PM 1173 views 0 times favorited 5 replies Add to Favorites Watch
View MrRon's profile
MrRon
4764 posts in 3241 days
09-04-2012 07:35 PM
I have an older PC 3” belt sander. I like it and it does a good job, but I find it hard to keep the belt tracking. It “walks” off in one direction and when I turn the adjustment, it walks to the other side. I can never keep it on track without constant steering with the adjustment screw.
5 replies so far
View Tennessee's profile
Tennessee
2873 posts in 2512 days
#1 posted 09-04-2012 07:39 PM
It could be a couple things. Does the drive roller have any play in it? What brand belts are you using, and are they fairly true? (Stand one up on a flat bench on edge and see how it stands.)
Is anything vibrating on the front end, and does the front roller have any play in it?
Lots of possibilities.
MrRon
#2 posted 09-04-2012 07:56 PM
If I run it without sanding, the belt runs true. It’s only when I start sanding does the belt start to wander.
View bandit571's profile
bandit571
19990 posts in 2680 days
#3 posted 09-04-2012 08:17 PM
Check the tensioner? If it acts up when you start to use it, then the belt is not being held tight enough.
MrRon
#4 posted 09-05-2012 04:22 PM
Thank you all. When I get back to my shop after the weather clears up, I will check.
View Bill White's profile
Bill White
4929 posts in 3958 days
#5 posted 09-05-2012 04:26 PM
Is the tracking knob holding?
I had the same prob on my old (won’t die) Ryobi sander. The knob would rotate when sanding. I replaced the tension spring under the knob and solved the tracking issue.
Bill
-- bill@magraphics.us
