How do i clean a leather strop
« back to Hand Tools forum
Forum topic by chrisstef posted 09-03-2012 09:10 PM 4113 views 0 times favorited 12 replies Add to Favorites Watch
View chrisstef's profile
chrisstef
17423 posts in 3029 days
09-03-2012 09:10 PM
Topic tags/keywords: strop leather cleaning
Hey gang, as always im looking to have some questions answered. I was able to quickly run out this morning and hit a tag sale where i picked up this cool old leather strop with brass hardware. The leather still feels pretty good, not stiff at all, but i would like to clean it a bit before i get to using it. Any tips or instructions out there for cleaning leather?
12 replies so far
View Don W's profile
Don W
18754 posts in 2591 days
#1 posted 09-03-2012 09:39 PM
just use soap and water on a cloth. Not to wet, just damp.
chrisstef
#2 posted 09-03-2012 10:08 PM
Sounds good Don. It looks like theres quite a build up of compound on it. Should i scrape it off first?
Don W
#3 posted 09-03-2012 10:09 PM
if you’re asking what I would do, I’d just start using it.
chrisstef
#4 posted 09-03-2012 11:10 PM
roger that.
View Sodabowski's profile
Sodabowski
2374 posts in 2856 days
#5 posted 09-03-2012 11:24 PM
+1
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
View OnlyJustME's profile
OnlyJustME
1562 posts in 2400 days
#6 posted 09-04-2012 12:12 AM
Could use saddle soap on the back side of it to clean the dirt off and keep it from cracking but i wouldn’t worry about the compound side. just reload with a bit of new compound and use.
-- In the end, when your life flashes before your eyes, will you like what you see?
View rance's profile
rance
4258 posts in 3184 days
#7 posted 09-04-2012 12:24 AM
So did barbers use the same compound that us woodworkers do? Their blades are much different.
Any Barbers on the list?
chrisstef
#8 posted 09-04-2012 01:06 AM
Im thinkin this was a barbers but i have no idea. Theres actually 2 pieces of leather. I can faintly make out a circular badge reading finish this side. One seems a little more coarse than the other. Its loaded with compound appearing to be red and green.
View MisterInquisitive's profile
MisterInquisitive
32 posts in 2120 days
#9 posted 09-04-2012 01:10 AM
If you’re going to use it to strop razors, you can use regular chromium oxide crayons, such as those from Lee Valley, or CrO2 powders, available from straight razor supply vendors online, such as Star Shaving Supplies. Saddle soap is a good idea to clean it, but be advised that used strops may have old pathogens in them. But what’s a little hepatitis among friends? If it was in good shape I might use some hydrogen peroxide and give it a go. Probably better if they haven’t been used for a long time, to give any bugs time to dry up and die. You can also use it for chisels and plane blades, but if you do don’t subsequently use it on a razor. Burrs and bits of swarf from plane blades and chisels tend to embed in the strop, and sharp corners dig deep scores in the strop, which makes the strop unsuitable for straight edge razors; any nasty little junk like that can degrade a straight razor blade. Not a barber BTW, just a cutthroat razor shaver who has learned much of the above from an acquaintance who is a straight razor aficionado.
chrisstef
#10 posted 09-04-2012 01:29 AM
Great info and insight Mr I. I plan on charging it with green honing compound for my plane irons and chisels. I think a little cleaning with a wet rag will do fine. Im gonna leave the straight razor shave to Tony my barber. I almost chopped up a belt a few days ago for just this purpose so im glad i found it.
View waho6o9's profile
waho6o9
8207 posts in 2600 days
#11 posted 09-04-2012 01:36 AM
Great advice.
+1 for saddle soap.
View lumberjoe's profile
lumberjoe
2899 posts in 2271 days
#12 posted 09-04-2012 01:44 PM
I have never used any compounds on strop, and I use mine a lot. The only time I take a chisel to the sharpener is when I need to rework the bevel or if the edge is damaged in any way. Otherwise a good stropping makes it as good as new (when you start with a good edge to begin with). Should I be using some sort of compound? Neither my dad or grandfather ever did (and I am using the same strop btw).
