| Forum topic by hamburglar | posted 261 days ago | 1058 views | 0 times favorited | 22 replies | ![]() |
261 days ago |
Hey folks, new to the forum as well as woodworking. (I’m a carpenter / handmade log home builder by trade though. Just never dabbled in the finer sawdust making until recently) So… I ordered a 10 board foot hard white maple lumber pack from an online retailer. It was 4/4 S2S and SLR one edge. It was shipped quickly and arrived nicely packaged. I think I might have had my hopes too high for what I was receiving though? I understand that being select or better that there is a higher percentage that will be clear but not all of it, and the lumber fell within that. My disappointment came in the S2S and SLR portion of this product. I was figuring that with both of those processes happening to the lumber that I would just be able to rip and crosscut to the dimensions I needed and get started on my project. Unfortunately though all of the pieces I received had a bow or even multiple ‘waves’ to them. I went ahead and cut them to the dimensions needed figuring maybe the shorter length would take away enough of the bow that it wouldn’t be a problem. I was wrong though and now have many pieces with a minor bow in them. So what I am asking is if this is normal? Even though this lumber is milled do I still need to process it further, or just a bad batch? I was hoping this would be ready to go seeing as I don’t have a jointer or planer yet. |
22 replies so far
#1 posted 261 days ago |
Every cut releases stresses in the timber. That is why you rough dimension the timber first and let it settle. The timber also passes through many different environments from leaving the mill t arriving with you. So unless it is plywood, if it is wood it will move. jamie -- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe |
#2 posted 261 days ago |
Hey there. :) Where did you get your lumber from? I find that I will usually need to edge joint the pieces because of the same findings as you. I don’t have a jointer so I use my router table as a jointer. I have a simple fence I made specifically for this purpose; it’s nothing more than a 4” wide piece of plywood with a notch cut for the bit and a piece of plastic laminate glued to the outfeed side. I set the fence so the bit is even with the outfeed side and it trues up the edge nicely. Then it’s off to the table saw for the rest of the cuts. It works for now, but I’ll probably get myself a planer and jointer for christmas. -- He who dies with the most tools... dies with the emptiest wallet. |
#3 posted 261 days ago |
Most S2S never sees a jointer. They just plane both sides so it looks pretty and is close to the thickness you want. So even when it is in THEIR hands, it can still be wavy. Next time order it ROUGH, let it sit in your shop for a couple of weeks, then get it milled(S2S) properly, starting with jointing the first face. Google “Squaring lumber” if you want more info. on getting it square. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#4 posted 261 days ago |
RE: “Most S2S never sees a jointer”, actually it depends upon the retailer. Wall Lumber, as well as others, use an Oliver Jointer – Planer to S2S lumber, and this provides a true jointed surface. -- Scott, North Carolina, www.quartersawnoak.com |
#5 posted 261 days ago |
Thanks for the quick replies. So it seems that my expectations were set a little high… Wasn’t something I had researched beforehand so I didn’t know exactly what to expect. My only other hardwood buying was some 4/4 poplar that I picked up from a local distributor and it was smooth on one edge and one face. @NiteWalker Here is the package I bought I am also going to be setting up my router table for edge jointing as soon as I rebuild it. The MDF one I had before isn’t standing the test of time. For the case I built for my son I was doing all of the cuts on the TS too. For the thickness I ripped them to 3/4” wide, and then sanded the saw blade marks out. For width I just ripped them normally, and for length I used a TS sled I made seeing my 12” SCMS isn’t good for anything but rough framing after years on the jobsite… @rance Next time I am definitely ordering it rough. By then I should have acquired the tools to deal with such lumber as well. I get paid tomorrow and there is a hole forming in my pocket for the DW734. |
#6 posted 261 days ago |
for what that place charges i think it should have been flat when you got it. i would have called them up and bitched. they want nearly $6 a BF for S2S maple |
#7 posted 261 days ago |
What kind of plans do you have for a router table? My current table is a sheet of 3/4” mdf with formica on one side and it’s held up ok, but I’ll be replacing it very soon with a new one I’m in the planning stages of building. Wall lumber is good too; probably the cheapest for the 20bf packs. The 734 has been on my wish list for a long time too. Try to get a mover’s coupon from the post office to bring the price down a bit. -- He who dies with the most tools... dies with the emptiest wallet. |
#8 posted 261 days ago |
Your package likely came from the Phoenix store and, would be really dry. No telling what climates or weather conditions it passed through getting to you. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#9 posted 261 days ago |
Never trust cuts from any mill. even ones you trust. Big ones are trying to turn out too much to be perfect and smaller ones sometimes simply aren’t equipped to be perfect. -- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability |
#10 posted 261 days ago |
Scott - Its good to know that some places to it right. :) Hamburgler - That is soooooooome expensive Maple. I can get it for less than $3 most often. Yeah, at least call them back and tell them your story. I wouldn’t expect much, but you might be surprised. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#11 posted 261 days ago |
@NiteWalker I have been looking at the plans for the Woodsmith router table and might give that a go. I might pick up one of those plates like you’re getting. I need the blank one though seeing I bought a Craftsman router. Thanks for the suggestions on the lumber… Lesson learned, especially when I could’ve had 2x the lumber at $10 more.. @Gene It did come from the Phoenix store. @Rance ROFL, this is something I am going to have to chalk up as a loss / mistake. I should have just taken the initiative to drive 60 miles south to the ‘local’ hardwood supplier. I probably could’ve asked away on milling it, received a better price, and felt better in the end. |
#12 posted 245 days ago |
Just so you know, whenever you’re not happy with what you receive from us we want to know about it and fix it. I just caught this thread now, some 2 weeks after the fact, but I figured this is still worth saying. Our crew is always ready to help and discuss. 800-423-2450, or orders@woodworkerssource.com. -- Woodworkers Source: Marketing Manager |
#13 posted 245 days ago |
I pick up my boards from LL Johnson. I let them surface both sides cannot beat 10.00 for 100 bdft, saves on my planer. They do a great job and the prices are good. I see your from Idaho so picking it up in Michigan would be a bit of a drive. |
#14 posted 245 days ago |
Wood is like a box full of chocolates, ya never know what your going to get. I Have taken many times rough lumber and SLR and see it do weird things. Looks like Mark has the right approach into dealing with this type of issue. A company’s worth in my book is not if they have had issues but how they take care of them. Even getting dimensioned lumber exactly ordered how you want it, you may still have issues by the time it arrives to your door step. If it came to you perfect and you did not let it acculimate in your shop for a week or two you would be asking for disaster in my opinion. Wood is like a good Lady, treat it right it will love you forever treat it bad and it will have it’s vengence on you. Good Luck…... -- What we do in life will Echo through Eternity........ |
#15 posted 245 days ago |
I’m glad I received my lumber from fellow LJer Bob, www.bobkloes.com, fair prices and Major kudos for Woodworkers Source to step up to the plate. Let us know |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3550 |
15787 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
