| Forum topic by motownjg | posted 262 days ago | 1339 views | 0 times favorited | 18 replies | ![]() |
262 days ago |
I’ve had a Makita cordless and corded drill since 1982/1983 and have never replaced the motor brushes. Should I? Both work just fine, although well-used, they seem to have the same power/battery life they’ve always had. But I’ve read some people replace the motor brushes for better performance and I thought I’d ask. What’s the consensus? Replace them when the motor bogs down? Or on a regular service interval? Thanks John -- John |
18 replies so far
#1 posted 262 days ago |
If you wait until you have problems, then you waited too long. Pull them out and check them. If they get too short and the little wire inside them starts rubbing on your armature, it will damage it. Look up new brushes and compare. They are cheap. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#2 posted 262 days ago |
A lot of brushes have wear lines; if they’re close to or at the wear line, replace them. Another good rule of thumb is to replace them if they’re shorter than they are wide. -- He who dies with the most tools... dies with the emptiest wallet. |
#3 posted 262 days ago |
Where can I look for advice on how to do this procedure? I have a Milwaukee Sawzall and it clearly has access screws to the brushes on the outside of the housing. But the Makinta corded and cordless drills don’t have anything obvious for me to remove to access the brushes. Seems like I’d just have to take it apart entirely and see what’s inside. No? Thoughts? John -- John |
#4 posted 262 days ago |
Some don’t have access to the brushes.. for example, my Makita cordless has a sealed DC motor and the brushes are not replaceable. If you don’t see access screws/covers for the brushes, then yours may or may not be replaceable. Instead of tearing it apart to find out, it’s usually easier to take a look at the exploded parts diagram for your tool first. Most tools have them in the back of the manual, or you can find them online at places like ereplacementparts.com Cheers, -- Brad in FL - To be old and wise, you must first be young and stupid |
#5 posted 262 days ago |
That was my thought. I found several internet sites that had exploded diagrams of the Makita 6095d and none of them specifically referred to “brushes” in the parts diagram. Makes sense that they’re sealed instead of replaceable. Also makes since since the thing has run like a champ for over 30 years. Oh well. Maybe I was worring over nothing. -- John |
#6 posted 262 days ago |
I have an old 6012HD which uses the same motor, and you can’t replace the brushes.. you would need to replace the motor if it ever goes out (about $40). I also have a just slightly newer but still 9.6v 6226D that is the same, although the replacement motor for it is only about $18. But like you say, these things just keep working like a champ, year after year. I think I paid something like $20 for the 6012 about 20 years ago, and $15 for the 6226 about 5 years ago and have used the snot out of both of them (and both were used when I bought them, so I have no idea how much abuse they took before I got them). I’ve thought about replacing them with a newer, higher voltage model, but I can’t imagine what it could do any better than the ones I have now, other than maybe have that fancy little LED light on it :) Every time I do get the urge, I go look at the prices of new ones and that gets rid of it pretty fast.. particularly when I look at the festool! For that kind of price, I would expect them to throw in a mariachi band, case of tequilla and a couple of hookers! Cheers, -- Brad in FL - To be old and wise, you must first be young and stupid |
#7 posted 262 days ago |
It may be a brushless motor. If there is not access from the outside, then I expect you have a brushless motor. Google “dc brushless vs brushed motors” and you’ll find pertinent information such as http://en.wikipedia.org/wiki/Brushless_DC_electric_motor . -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#8 posted 262 days ago |
I have Makita 9.2 volt drills that I have had since 2001, that I use every day and they still run just fine. Just keep using them until they quit. I think mine may outlive me! Ha ha. -- In God We Trust |
#9 posted 262 days ago |
Your drill is as old as my youngest daughter. Great life for a cordless drill. -- Bob Kenosha Wi. |
#10 posted 262 days ago |
Same business on the corded makita drill? Runs fine, but no easy access screw holes to the brushes, so it must be sealed or brushless. Did they make brushless motors in the middle 1980’s? -- John |
#11 posted 261 days ago |
I have found that if the tool does not have the screw top brush retainer, it is a throwaway tool. I have several PC routers, and maybe 100 bucks of replacement brushes on the shelf to replace, and check them every couple of months. But my Makita drill motors are getting over 20 years old , and the batts, are getting so spendy that I am considering tossing all of them in a dumpster even though they still work fine. (it will be a responsible no land fill for the batts). -- Life is to short to own an ugly boat. |
#12 posted 261 days ago |
A cordless drill from 1982/1983. They don’t make ‘em like that these days ! -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#13 posted 261 days ago |
Pete, please consider giving them to someone that is willing to use them. Maybe they have good batteries and could use another drill. Or sell on CL. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#14 posted 261 days ago |
Outside replacement of brushes is a feature on most high priced tools. If they are not acceassible from the outside (a convenience feature), you will have to take it apart to get to the brushes. All have replacable brushes, except for the very cheapest tools, because replacement brushes are not part of their repair parts list (if they even have one). Go to a parts center like www.ereplacement parts.com for breakdown lists of parts available. |
#15 posted 261 days ago |
I had the 9.6 (?) volt Makita that took the long battery and when I needed a new battery it was more money than a new 14.4 volt unit. Are you getting your batteries rebuilt? |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3551 |
15788 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6161 |
