| Forum topic by sIKE | posted 126 days ago | 282 views | 0 times favorited | 7 replies | ![]() |
126 days ago |
I am working on designing a torsion box to support my RAS. I have never designed one of these before. The thickness and depth are what I am trying to determine. I am shooting to have the top of the RAS table level with the top of my Miter Saw Bench. With that taken into consideration, I have one more item to consider. The dust collection system is pre-ran against the wall and limits the total height of the torsion box itself, if I were to build the torsion box over it. The DC system I have drawn a 5” to make my life easy. I have two options from where I see it. I have been basing this design off of the Torsion Box episode of Wood Works (S04E09) Option A: Option B I am guessing that the RAS assembly is between 75 – 100 pounds (will get an accurate number here soon), the reason I ask this is how small should I make my grid work? I know Marks sized his to fit his brad nailer. After playing with the math the spacing from Left to Right will be 6 5/8” on center. Once I determine the depth of the box I will work out the spacing front to back. Will this work? Materials -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
