Trying to pre-plan a project and having mental problems
Forum topic by cassady posted 290 days ago 412 views 0 times favorited 8 replies Add to Favorites Watch
View cassady's profile
cassady
16 posts in 605 days
290 days ago
I am trying to plan a project that will eventually be an octagonally-shaped cart for my air compressor. I have the plan in my head but I apparently lack the brainpower necessary to figure out how to join the pieces of wood AND also figure out the angle I will need to cut the wood at to form the octagon. Picture an octogon about 2 feet across. If anyone has a tip for figuring angles and then also knows a good way to clamp angled joints, feel free to school me!
Thank you!
-- Cassady in Denver, CO
8 replies so far
View DIYaholic's profile
DIYaholic
7575 posts in 872 days
#1 posted 290 days ago
Doing the math for the angles wood hurt my brain right now…...
Clamping could be accomplished with a band clamp. Like this one on sale at Rockler.
-- Randy-- I may not be good...but I am slow!
View Ryan Haasen's profile
Ryan Haasen
341 posts in 598 days
#2 posted 290 days ago
Matthias Wandel has a video about how to calculate the angles for a polygon (10 sides). While that part may not be such a great help, he also shows how he glues the angles joints together. Here’s the link, hope it helps: http://www.youtube.com/watch?v=_CRJsn_pQ7Q&feature=relmfu
-- Ryan
View casual1carpenter's profile
casual1carpenter
261 posts in 672 days
#3 posted 290 days ago
cassady, this might help if I have the tolerances set right lol.
View tomd's profile
tomd
1336 posts in 1967 days
#4 posted 290 days ago
Just do a Google search for a segmented angle chart. An 8 sided ring will need and angle of 22.5 degrees on the end of every piece. To clamp them, form the ring with all sides in their place, glue then rap a band aroung it making sure its flat an in an even octogon shape, I use a large rubber band or belt clamp. After it dries screws or splines can reinforce the joints.
-- Tom D
View Howie's profile
Howie
2424 posts in 1120 days
#5 posted 290 days ago
360 degree circle-divide by 8 = 45-divide by 2 = 22.5 like tomd said. Key is dividing the circle by the number of sides.
I would use bisquits for alignment and a good glue along with a strap clamp or some type of rubber band. I buy surgical tubing at Lowes and it works great for rubber banding odd shapes.
-- Don't rollerskate in a buffalo herd
View helluvawreck's profile
helluvawreck
10904 posts in 1063 days
#6 posted 290 days ago
A really good program for a woodworker to have is a CAD program. It makes anything like this easy. A really good affordable CAD program is Turbocad.
helluvawreck aka Charles
cassady
#7 posted 289 days ago
Thanks for the info everyone! Appreciate the sharing
View Monte Pittman's profile
Monte Pittman
7209 posts in 535 days
#8 posted 289 days ago
8 pieces (obviously). Diameter X π (3.14) divided by 8 that’s the length of the pieces. All angles are 22.5 degrees. I build a lot of octogons.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
