cutout and finishing for a maple butcher block
Forum topic by Doug posted 09-01-2012 02:43 PM 1164 views 0 times favorited 4 replies Add to Favorites Watch
View Doug 's profile
Doug
28 posts in 2331 days
09-01-2012 02:43 PM
I just bought a 68” long x 31” wide x 3” thick piece of glued up maple on CL for 200 bucks. It is unfinished so im thinking that ill do the finishing myself. I also need to cut it to length and make a cutout for a cooktop. Does anyone have any suggestions on the cutout? I was thinking that a router template and multiple passes might be a good way to go. And if anyone has any suggestions on finishing it would be appreciated. Thanks
View Bill White's profile
Bill White
5148 posts in 4198 days
#1 posted 09-01-2012 05:33 PM
Router on a 3” thick top is gonna be a chore ‘cause it’ll take a long bit and a big router. Rough saw first, then route with a pattern would be my choice. Use several passes or you’ll overload the router. Finish? You didn’t state what application you would use for the top. Countertop, workbench?
Bill
-- bill@magraphics.us
Doug
#2 posted 09-02-2012 12:34 AM
I thought I mentioned that but it will be a kitchen island. The cutout is for the cooktop. I know I need a food grade oil to finish but just looking for any tips or suggestions. Rough saw cutout with what though? Circ saw? Jigsaw? thanks
Doug
#3 posted 09-06-2012 02:21 PM
No other ideas?? Anyone?
View Tennessee's profile
Tennessee
2893 posts in 2752 days
#4 posted 09-06-2012 03:05 PM
Can you even find a three inch long router bit? I would go with a good electric drill, if you have one, and drill a pattern just inside the cutout, using forstner bits or even spade bits which you can resharpen easily. Something big enough to get a recip saw blade in, like 7/8”
Then if you don’t have a recip saw, get one from HF which you will probably throw away when done, use a GOOD blade with a medium tooth count, and move from hole to hole approximating the cutout. Rasp the remainder of the hole into position by hand.
I would figure you will have some sort of flange on the cooktop, so it doesn’t have to be dead-on.
Three inch thick maple will be tough, burn and take out more than one blade, so attacking it in stages while knowing you are not committing to a huge mistake if a router ran on you seems like the way to go.
