Where can I find a portable sawmill for rent that will cut a trunk over 44 inches in dm?
Forum topic by John Fleming posted 09-01-2012 02:24 AM 33336 views 0 times favorited 12 replies Add to Favorites Watch
View John Fleming's profile
John Fleming
4 posts in 2060 days
09-01-2012 02:24 AM
We are about to cut down an old black walnut that has been dropping limbs the last couple of years. The tree has sentimental value to our family so I am hoping to cut multiple slabs from the length of the trunk – and use the wood for various projects including table tops. The tree is about 44 inches in diameter and, so far, I haven’t located anyone locally who has a portable sawmill that can handle a tree with a diameter over 36 inches. I live in East Texas.
Any thoughts or suggestions would be appreciated as I want to keep the slabs together (in one piece).
John Fleming
-- John Fleming
12 replies so far
View Scott Wunder's profile
Scott Wunder
13 posts in 2065 days
#1 posted 09-01-2012 02:32 AM
John,
We need to see photos before you go crazy cutting that thing up. If it is that big and a good quality log, it is worth more to sell it than cut it. The biggest walnut I have run into is 36” inside the bark at 10’. That is a size that had veneer buyers ready to come and see me. Unfortunately, the tree had nails in it, so I wasn’t able to sell it for as much. Also, I have a friend (David Stine) that builds slab tables that would be very interested in slabs from a tree that large and pay for them.
-- Scott Wunder, WunderWoods, St. Charles, MO. Read my sawmilling and woodworking blog at http://www.wunderwoods.com
John Fleming
#2 posted 09-01-2012 04:06 AM
Scott – Thank you for the reply. I will take pics tomorrow and post. While I don’t know much about the quality of trees, I suspect it is of lower quality because of the likely presence of nails and such and because a limb recently fell off that looked rotten. Much of the tree, however, has fresh leaves on it. I’ll get the pics up. Thanks again. John
-- John Fleming
View WoodMizerGuy's profile
WoodMizerGuy
6 posts in 2240 days
#3 posted 09-04-2012 12:43 PM
Hi John,
Wood-Mizer has a form that you can use to find local sawmill owners. Feel free to plug your info in, and we’ll look up guys in your area.
http://www.woodmizer.com/us/ResourceCenter/FindaCustomSawyer.aspx
Jake
-- Check out www.facebook.com/woodmizer to join our group of portable sawmill fans!
View Scsmith42's profile
Scsmith42
125 posts in 2643 days
#4 posted 09-04-2012 02:43 PM
John, I work with large diameter logs all the time, and these are outside of the realm of your typical sawmill operator. Fortunately for you, there is a business outside of Austin that specilizes in slabbing and milling very large diameter logs. Your best bet is to trailer your log over to Brandon Berdoll’s operation. He can both mill and kiln dry your wood. Let me know if you would like his contact info.
If you follow Jake’s advice and find a local Woodmizer owner, you’re going to need to make sure that they can handle a log weighing in the neighborhood of 6000 lbs (44” BW x 10’ long log). Plus, you will need to sacrifice some of the logs diameter as even the largest, commonly available Woodmizer mills can only handle a 36” dimeter log.
I think that you’ll find that most Woodmizer operators are not equipped to handle logs this size. They are great mills for logs under 30” diameter though.
-- Scott, North Carolina, www.quartersawnoak.com
View HalDougherty's profile
HalDougherty
1820 posts in 3203 days
#5 posted 09-04-2012 03:15 PM
Scott,
But I was wrong. They have a monster of a machine in their commercial division. It will handle a 67” diameter log. The bed can be extended to as much rail as you can afford. Just like the LT15 or a Timberking 1220 like mine. The price for this beast is industrial quality too. They don’t try to use a cantilever sawhead on this monster. Wish I had one!
http://www.woodmizer.ca/Products/IndustrialSawmills/WM1000Sawmill.aspx
-- Hal, Tennessee http://www.first285.com
View Doss's profile
Doss
779 posts in 2231 days
#6 posted 09-04-2012 07:33 PM
Hal, do you have a price on that bad boy? I’m already salivating.
John, this is a very large log for a bandsaw mill (as you have found out). I don’t know of one that is truly portable that will handle this.
You may be sitting on a potentially very valuable log like Scott said.
It’s best to find a sawyer who knows what they’re doing and isn’t just going to cut this thing as fast as they can. Cut for quality not quantity or speed.
-- "Well, at least we can still use it as firewood... maybe." - Doss
Scsmith42
#7 posted 09-04-2012 09:01 PM
Hal, they introduced the WM1000 earlier this year, but there are not very many of them available to mill lumber… I researched them when they came out, but the price does not have a positive ROI versus my current setup.
That’s why I said “largest, commonly available Woodmizers”....
And you’re right – they are not cheap.
Doss – you NEED a WM1000! Go buy one so that the rest of us can salivate. Of course, you’ll need to buy some extra large forklifts or cranes for taking care of your log feeding needs!
View Doss's profile
Doss
#8 posted 09-04-2012 09:55 PM
Yes sir! I think a heavy equipment purchase would be in order if I got that thing. LOL
I’ll keep looking at 36” mills for now and ignore the fact that that beast exists.
View WDHLT15's profile
WDHLT15
1732 posts in 2442 days
#9 posted 09-05-2012 01:14 AM
Hopefully your log will not be full of nails and iron. Sadly, most yard walnut are. Be sure you understand the terms and conditions on the front end that apply when the sawyer hits metal.
View Post_Oakie's profile
Post_Oakie
84 posts in 2120 days
#10 posted 09-11-2012 08:32 PM
Couple of thoughts. A swing blade mill (Peterson or Lucas) can handle that log. The swing blade mill can cut out one slab, and cut the rest into dimension lumber, but both have slabbing attachments that drive a chain saw with a 4- stroke engine. I have milled walnut that size with a double-ended chain saw mill (Granberg Alaska mill), running a Husqvarna 372 on one end and a Stihl 660 on the other. Every slab took about 20 minutes and a tank of fuel in each saw, but it was worth it. As happy as I am with my Norwood band saw mill, you might consider a Hudson. The Oscar 52 can handle 52” logs, though I’ve never seen one in person. That’s asking a lot from the mill!
-- Good judgement comes from experience. Experience comes from bad judgement.
View TreeBones's profile
TreeBones
1827 posts in 3989 days
#11 posted 03-24-2017 03:01 PM
The Sawmill Finder
http://portablesawmill.info
Better late than never…
-- Ron, Twain Harte, Ca. Portable on site Sawmill Service http://westcoastlands.net/Sawmill.html http://westcoastlands.net/SawBucks2/phpBB3 http://www.portablesawmill.info
View avsmusic1's profile
avsmusic1
246 posts in 651 days
#12 posted 03-24-2017 03:22 PM
I had the same thought as Post_Oakie – This seems like a job for a chainsaw mill with a large bar
