Blade will not lower completely below table
Forum topic by missingdigitworkshop posted 262 days ago 949 views 0 times favorited 39 replies Add to Favorites Watch
View missingdigitworkshop's profile
135 posts in 1296 days
262 days ago
Topic tags/keywords: table saw problem
I have a Craftsman 113.12171 Table Saw.
The blade raises and lowers fine but I can not get the blade to go completely into the table. The lowest I can get the blade is 1/16 inch above the table. This is not a huge problem but is very frustrating.
Does anyone have any ideas how I can try to get the blade to go completely into the table?
-- Do not be discouraged by those who don't. Be inspired by those who do.
39 replies so far
View Loren's profile
4877 posts in 1816 days
#1 posted 262 days ago
There will be a mechanical point where the mechanism
bottoms out. The likely cause is there is sawdust packed
in there preventing the mechanism from going to its
end point.
#2 posted 262 days ago
Loren: I checked for dust and chips and have blown it clean but still can not get the blade to go completely into the table. Is there possibly something that could have gotten out of whack that I need to adjust?
View knotscott's profile
knotscott
4187 posts in 1543 days
#3 posted 262 days ago
Did you check the gears for something binding?
View Tedstor's profile
Tedstor
926 posts in 800 days
#4 posted 262 days ago
Perhaps the threaded rod that accuates the elevation mechanism is corroded, dirty, or stripped? Might be worth taking an old toothbrush and scrubbing the rod with some machine oil.
Tedstor
#5 posted 262 days ago
Oh and just for grins, work the blade lock back and forth a few times.
View Jimbo4's profile
Jimbo4
710 posts in 931 days
#6 posted 262 days ago
Digit – I have the same problem. I’ve scrubbed, oiled, twisted, checked, moved, hammered, cursed, to no avail. It is what it is.
-- *Arachnoleptic*: The frantic dance performed just after you've accidently walked through a spider web.
View Scott Wunder's profile
Scott Wunder
13 posts in 267 days
#7 posted 262 days ago
It is frustrating when the only table in your shop that has a chance to have a clear work surface on it, is also the one with a blade sticking out. I have an old Delta Unisaw that does the same thing. Mine will lower completely if I grab the handwheel and pull it towards me. There is some hidden slop in there that doesn’t show up otherwise. When I do this the blade drops about 1/8 inch and doesn’t stick up above the table.
-- Scott Wunder, WunderWoods, St. Charles, MO. Read my sawmilling and woodworking blog at http://www.wunderwoods.com
View okwoodshop's profile
okwoodshop
386 posts in 1343 days
#8 posted 262 days ago
“CRAPSMAN” nuff said??
View toolie's profile
toolie
1098 posts in 796 days
#9 posted 261 days ago
scott…... that “slops’ is, i believe, adjustable. check where the elevation rod intersects with the motor bracket. it’s not easy to inspect with the table and motor in place, but i believe there is a fix for it.
okwoodshop….... would that all tools today were made as well as those old emerson electric built TSs sold by sears and ridgid. i have one of them, with a t-2 fence on it that would have to be pried out of my cold dead hand before i’d give it up. i’m selling my unisaw to make room for the two emerson built 10” CI contractor TSs i have. maybe a lot of sears” recent products qualify as “CRAPSMAN”, but it’s hard to malign a well maintained 113 series c-man table saw that’s equiped with a proper fence, IMHO.
Tedstor
#10 posted 261 days ago
yep. A 113. table saw develops a minor issue after 20+ years of use, and someone calls it a “crapsman”. LOL.
What should we call the Scott’s Unisaw that has the same problem. :)
I also have a 113. with a T2 and am 100% satisfied. And if my 113 developed the mentioned issue, I’d buy another $75 113 off craigslist, slap on the T2, and keep on truckin.
View Grandpa's profile
Grandpa
2380 posts in 843 days
#11 posted 261 days ago
Have you checked for a mechanical stop on the htreaded rod? I think some of those saws had a collar with a set screw that stopped the mechanism.
knotscott
#12 posted 261 days ago
”“CRAPSMAN” nuff said??”
Why not just insult his wife and kids? It’d be just as helpful, and no less offensive.
View Tenfingers58's profile
Tenfingers58
56 posts in 846 days
#13 posted 261 days ago
I realize this does not fix the underlying problem but this is what I would do. Cut a piece of plywood, put a skirt around the bottom edge so it can’t slide on the table top. Cut a recess for the blade in the bottom.
This gives you a flat surface to work on without having to remove the blade all the time.
Another possibility would be to use a smaller blade.
okwoodshop
#14 posted 261 days ago
I apologize to all the CRAFTSMAN owners on here, I just have never had any of there tools that worked properly or lasted long. will keep my big mouth shut from now on.
toolie
#15 posted 260 days ago
grandpa…..on those saws, i am pretty sure those stop collars were only on the tilt mechanisms.
tenfingers50…..how would one use the TS fence with that adaptation?
showing 1 through 15 of 39 replies
