| Forum topic by Cole Tallerman | posted 261 days ago | 508 views | 0 times favorited | 12 replies | ![]() |
261 days ago |
So I have a great spot just outside of my shop that I was thinking I could put my dust collector. It will be hidden from all the elements except temperature. How do you think it would fair through the cold of the winter? Thanks! |
12 replies so far
#1 posted 261 days ago |
The only problem I can see is that the bearings may seize if their lubrication gets too sluggish. How cold are you talking about? -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#2 posted 261 days ago |
The problem w/ that is that you will be sucking all of your heated outside during the winter. That is if you heat your shop. Plus machines don’t like super cold, they tend to break, and grease thickens making it tough on bearings. -- Bondo Gaposis |
#3 posted 261 days ago |
The best part would be you wouldn’t have to use a bag on the collector, just let it suck the dust and spit it outside into the yard… That would be a huge + -- Dan - "Collector of Hand Planes" |
#4 posted 261 days ago |
Looking at your location, you are well inland so salt spray / rust shouldn’t be a concern. However you also live in New England. Not exactly a warm climate. I can see the motor / impeller siezing up due to frozen bearings / lubricant… A small enclosure that you could keep above freezing somehow would likely prevent this… -- Manufacturer of fine quality sawdust since 1984. Comments and advice on my shop welcome. Check it out at http://lumberjocks.com/dbhost/workshop. Gladly accepting shop build donations! |
#5 posted 261 days ago |
I live not far from Niagara Falls, NY. I was thinking of moving my DC outside my shop, but I was going to enclose it in a little shed, insulated, and possibly put a 60 watt bulb in it. In summer it would exhaust to outside. In winter I would have a hatch I could open that would let the air back into the shop BUT it would go though a largish box made primarily of furnace filters up in the trusses. First I need a couple more windows though. I have french doors and one small window. Both on the same wall. Great for maximizing wall space but lousy for ventilation :) |
#6 posted 261 days ago |
I have a cyclone dust collector with a 8” outlet to the filter. I have been contemplating adding a 8” “Y” connector with balst gates on each leg of the Y so that I could vent it outside when the weather is good and then vent it inside-only to the filter when the weather is not so good. Still would have to empty the sawdust drum but this would solve part of the issue. -- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com |
#7 posted 261 days ago |
I have mine outside with out any problems for 10 years now. I’ve built some small dog houses to put my DC in. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#8 posted 260 days ago |
That’s a great idea! It will also make the DC not as loud. It might be so quiet that you need to put a light in the wall, then you know when the DC is on or off. Hope this helped! AJ -- If I can do it.....so can you! -AJswoodshop |
#9 posted 260 days ago |
Sounds like a winner, great space saver if you have a small shop also -- Norman |
#10 posted 260 days ago |
In central Alberta, we commonly get temperatures for a week or so in the – 40 degree range, and my Oneida Cyclone is in the barn, unheated, but protected from elements. I have heard all the stories about sucking cold air in and losing the heat in my shop, I have gone through 2 winters with no noticable change in temperature when running my system. Mine is heated with a radiant gas heater. My DC system runs in the really cold weather with no issues to date, I work in my shop when it is too cold to work outside, so that is a lot in the winter. -- Randy "You are judged as much by the questions you ask as the answers you give..." |
#11 posted 260 days ago |
Ok so it sounds like I’m going to do it and yes AJ the noise is a big factor as well as space. I’m thinking that I will build a small inclosure around it but just put a garbage pail beneath it. I also think that I will insulate it and not close the gaps around the pipe so that hopefully some warm air will leak in and keep it a little warmer then the outside temps. All of your responses were wary helpful so thanks!. Jim, it makes me happy to know that you do that because if i remember correctly, you have the same hf dust collectors as i do. |
#12 posted 260 days ago |
One of the smartest things I ever did was put the dust collector/chip separator in the unheated garage attached to my shop. Only prob is it is so quiet I can easily forget to turn it off. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1523 |
3542 |
15756 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6150 |
