Using a Squeegee to spread finish? Poly-U on a table top or something tougher?
Forum topic by Holz_und_Geschichte41 posted 259 days ago 523 views 0 times favorited 3 replies Add to Favorites Watch
View Holz_und_Geschichte41's profile
47 posts in 1185 days
259 days ago
I am at the point where I am staining the base and table top of my future dining room table. That part is sorted out. For the finish though I am a bit torn and uninformed. Would a normal polyurethane finish work as the table top will experience years of use? Also, from my previous finishing experience with polyurethane it can sometimes not set evenly. Has anyone used a squeegee (sp?) to reduce that from happening, for an even spread? Considering the surface area it seems like a good idea but…..never tried it and I don’t want to make a mistake that could have been avoided by seeking out good advice.
Thank you ahead of time!
-- Ryan, Arizona
3 replies so far
View Clint Searl's profile
Clint Searl
844 posts in 526 days
#1 posted 259 days ago
Ryan, the easiest durable finish for your table top is a waterborne poly floor finish. Apply a light first coat and smooth it back with 220 paper or maroon Scotchbrite. Follow with two full wet coats without over brushing. After a couple days, rub it out with 0000 steel wool and Butcher’s or Johnson wax. Polish with an old tee shirt or towel.
I like Bona Mega the best, but that may be hard to find. Second choice is Varathene.
-- Clint Searl.............We deserve what we tolerate
View Bill White's profile
Bill White
2600 posts in 2125 days
#2 posted 259 days ago
Ryan, listen to Clint.
The squeegee is like a trowel.
Finishing is work. There is no such thing as an easy, brainless finish. Spend the same time in finishing as ya spent in building an object. The rewards are worth the time spent.
Bill
-- bill@magraphics.us
View gfadvm's profile
gfadvm
6600 posts in 855 days
#3 posted 259 days ago
I’d spray it or thin and wipe it on but would definately stay away from the squeegee.
