Our wooded acres have a lot of dead Dutch Elm trees that are still standing and solid. There's a guy in a town 10 miles away with a portable saw mill and I want to turn those Elm trees into lumber.
Does anyone have any experience with something like this?
Its on my to-do list. You can still air dry your lumber. Whoever said lumber will never dry was dead wrong. All lumber will take the moisture content of its surroundings. An attic is a good spot if you have one.
I've been air drying lumber for years. My bench is made from air dried Elm, just like you want to cut.
A kiln is a cool thing to have though, and turns a years worth of drying time in a few weeks. It also helps stabilize the lumber, especially lumber with a lot of pitch.
There are several examples here on LJ. Here is one I finally remembered to favorite.
I helped someone build one. They had doors through the ends which seemed like it would be difficult to load. The pics above make more sense. I also thought it would be cool to put the whole affair on hay wagon running gear to move it to take advantage of the moving sun.
Thanks Don! You've always been on top of answering my questions and I really appreciate that. Some years ago Dutch Elm disease, left all of our Elm tree's dead. It's easy to identify them because the bark all falls off and the wood trunks are very white-ish. I have no idea how good the quality of elm is, I just never here that much about Elm or if it's worth getting milled.
Elm can make very beautiful wood. I really like. Darren Nelson of Nelsonwoodworks.com also has plans for a home made kiln (non solar). I liked them, might give them a look. Good luck and welcome to LJ's.
Cutting dead elm can be very dangerous. Dead limbs can break off when vibrated by the chainsaw or when the tree starts to fall. More than a few people were killed or injured when the disease went through here (Michigan) 30 years ago when folks cut it for firewood. I've done it a lot, but my felling cuts were crooked because I was always looking up.
having doors at the end can be a good thing
but want to avoiding to work in low tight space many
makew rails in the floor and outside the kiln
and use a low wagon on the rails and work outside
when stacking and unloading the wagon
you can use attic as said as well as a greenhouse to dry your wood
as long as you have enoff airfloow between the layers of wood
@ Paul Miller - funny that you mention the disaster in Michigan. I watched what it did in Detroit and the city never looked the same. Hardly ever see elm on the hoof, as it were. The local Habitat for Humanity store also carries lumber harvested locally, and the last time in they had elm. Had to wonder where they found it after all of these years.
Re: the solar kiln… Is it worth the effort? For a hippie with a commercial need I can see it, but is it worth the time and expense for someone using less than hundreds of board feet per year? Maybe if you're planning to sell the stuff?
Emma, in my opinion if you have trees at your disposal, it is worth it to cut and dry your own. The ones that buy perfect lumber at the box stores will never understand the joy of taking it from tree to finished product. I am building a kiln in my shop. Yes i will go through thousands of board feet of lumber, but I would do it even if I didn't.
It's a matter of scale and space. You wouldn't build a car that you'd go on to use once or twice a year, so why a kiln? If you're large scale enough to make it worthwhile then go for it. But if you're only a couple of hundred feet per year then why not just air dry? FWW I almost always have stickered piles drying, cut from trees that mean something special to us, and that's pretty cool.
i have a book that has a good plan in it for a solar kiln. it says they are actually easier to use b/c you don't have to monitor the moisture level since the night air cools it and prevents it from drying to fast. i also wondered about elm. i found some in the firewood pile and it was beautiful! i asked what it was and my boyfriend said elm. i have never heard of it being used for projects….i think i will create a new forum lol
There ate quit a few elm projects. My bench top is primarily elm.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
