Repair a try square?
Forum topic by Damian Penney posted 489 days ago 217 views 0 times favorited 9 replies Add to Favorites Watch
View Damian Penney's profile
Damian Penney
1030 posts in 890 days
489 days ago
Is there anyway to correct a try square that isn’t true? I brought back an old one that my Grand Dad used to use but it isn’t true, is there anyway to fix this?
View GMman 's profile
GMman
1370 posts in 596 days
489 days ago
would you have a photo of it
-- --<<<<<< I will not stop until I get it right. >>>>>>--
View marcb's profile
marcb
705 posts in 572 days
489 days ago
How is it held together? As GMman said, pics please
Damian Penney
489 days ago
Here is the square, a bit worse for wear but should clean up nicely if I can get it square.
try square
Damian Penney
489 days ago
I also got two planes and a nice marking gauge with micro adjust
View John Ormsby's profile
John Ormsby
503 posts in 635 days
488 days ago
There is a way to tune up your square. I have done it before. It involves tapping the flat side of the blade close to the leg. This tapping, when done correctly will open the angle and close the angle. I will caution you to do some research into this subject. It takes very skilled hands and knowledge of the techniques to get it right. You could begin by looking on the net info on tuning framing squares. They are done in the same fashion.
-- Oldworld, Fair Oaks, Ca
marcb
488 days ago
Nice tools.
I’m trying to dig up something I know that went over making squares like that which would help point out how to fix it.
You should also check to see if its just blade wear that is making it off or if the blade moved in relation to the handle over time.
If its the latter you should be able to fix it with a few pieces of brass round (knock the old pieces out set the square and pean new ones in)
3710 posts in 878 days
488 days ago
Hi Damien;
There are actually three ways to fix the square. The easier two have been mentioned.
When peening a square, use a semi rounded over nail set, or something along those lines. To have the blade move dimple the corner that you want to close. This stretches the metal and pulls it back into square.
The center pins on the diamond may be a little loose and have allowed the blade to move. You can try tapping it back into place with a dead blow mallet. If you’re able to get it to move, peen the pins in tighter.
The next method and last resort would be to grind or file the two edges of the blade. This is if the blade is only slightly off.
Have fun,
Damian Penney
488 days ago
Could you explain peening a bit more, not sure I fully understand the process.
View GaryK's profile
GaryK
9537 posts in 887 days
488 days ago
Peening puts dents into the steel causing it to expand.
If it off a small bit you can rub the body of it on a piece of sandpaper taped to a good flat surface. Put pressure on one end or the other depending on which direction it’s off.
I don’t think I would mess with the blade if I could avoid it.
I just made a post on squaring a carpenters square which shows you how to use peening.
http://lumberjocks.com/topics/4127
