Screws for Pocket Hole Joinery
Forum topic by Mike Gilbert posted 08-30-2012 06:55 PM 20745 views 0 times favorited 12 replies Add to Favorites Watch
View Mike Gilbert's profile
Mike Gilbert
31 posts in 2099 days
08-30-2012 06:55 PM
Topic tags/keywords: drill-driver jig tip
I recently have been looking into pocket hole joinery for a cabinet project I am going to be starting soon. I have seen the pocket hole screws sold by KREG but I was wondering if there are other better / cheaper options out there. please let me know what kind of screws you use with your pocket holes. If KREG really makes the best ones I’d like to know but my gut tells me the same screw must be sold somewhere else out there without a brand name on it for much less. if anyone has found a better supply I’d appreciate the tip.
Thanks
12 replies so far
View Nighttripper's profile
Nighttripper
41 posts in 2164 days
#1 posted 08-30-2012 07:53 PM
An alternative are those sold by Mcfeelys.
http://www.mcfeelys.com/pocket-hole-screws
404 - Not Found
2544 posts in 2966 days
#2 posted 08-30-2012 08:21 PM
If you can find them, try Reisser. They come with a free Roberts No.2 (the square drive) bit.
View Murdock's profile
Murdock
128 posts in 2481 days
#3 posted 08-30-2012 08:47 PM
My local big box store carries some generic ones that certainly cost less. While they look the same they don’t seem to be as strong to me as the Kreg. I have managed to twist off several.
Could be that the size is slightly bigger and my pilot hole isn’t large enough, I have never measured. I don’t buy enough of them for it to really make a huge dent in the old pocketbook.
I have actually used the kreg screws for things other than pocket holes as well.
-- "Anyone who has never made a mistake has never tried anything new." - Albert Einstein
View lumberjoe's profile
lumberjoe
2899 posts in 2245 days
#4 posted 08-30-2012 11:25 PM
I managed to twist off some generics as well. I believe they were General brand. Poking yourself in the wrist with a square drive bit with all the force you can muster leaves a nasty bruise for a week. I’ve never had a kreg screw snap on me. I don’t care what they cost, I’m only buying those from now on. I also use them for non-pocket holed wood projects
View ShaneA's profile
ShaneA
6929 posts in 2595 days
#5 posted 08-30-2012 11:40 PM
There may be others, but the Kreg screw, is high quality. I also use it in other applications. Probably not worth the risk for minimal savings. IMO.
View WrathOfSocrus's profile
WrathOfSocrus
24 posts in 2449 days
#6 posted 08-31-2012 12:03 AM
The problem I have seen is that when you are joining two boards together with screws, the first board (one with the screw entering, in this case a pocket hole) cannot have threads biting into it. Using this insight, I go back after making my pocket holes and drill through with a bit as thick as the threads of the screws I happen to have handy. I have used deck screws, tap-cons, and even drywall screws. Obviously some screws are better than others, but in a pinch, any screw the proper length and of reasonable diameter can be used.
I know the drywall screws are flat head/countersunk type and will blow out the pocket hole if driven in forcibly, so I will tighten them by hand. I can’t see spending more money on screws than on wood for a cheap jig I may or may not ever use again. If it is for a project then I will get ones more appropriate for the job, but I haven’t bought the Kreg screws and haven’t had problems once I learned the tricks mentioned.
-- "To do is to learn. A brilliant man once said that... I think he had a beard, too." - Joe Burns, HTML Goodies
View Jim Finn's profile
Jim Finn
2656 posts in 2919 days
#7 posted 08-31-2012 02:53 PM
As WrathOfSocrus says ”... drywall screws are flat head/countersunk type and will blow out the pocket hole if driven in forcibly, so I will tighten them by hand…” This is what I do.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Brandon's profile
Brandon
4152 posts in 2948 days
#8 posted 08-31-2012 02:58 PM
I’ve done the same thing, but not because the screw snapped—but because the cheap screw bit I was using stripped.
-- "hold fast to that which is good"
Mike Gilbert
#9 posted 09-01-2012 01:19 PM
Thanks for the comments guys, sounds to me that it’s worth the price to go with the Kregs. I definitely don’t want to be snapping screws if I can avoid it.
View Sailor's profile
Sailor
543 posts in 3262 days
#10 posted 09-01-2012 01:28 PM
Yea, I use a pretty good bit of Kreg screws. I buy them off of Amazon in the 1000 count boxes, usually 4 boxes at a time. I use the 1 1/4” and 1” coarse ones.
-- Dothan, Alabama Check out my woodworking blog! http://woodworkingtrip.blogspot.com/ Also my Youtube Channel's Facebook page https://www.facebook.com/SailingAndSuch
View AndyDuframe's profile
AndyDuframe
48 posts in 3587 days
#11 posted 09-01-2012 03:02 PM
I’ve looked around for alternatives. I’ve found certain types of cabinet screws with the same head profile, but don’t see any big difference in price between them and the pocket screws. Guess I would have thought the jig manufacturers might run with the opportunity to over-price their fasteners, but not really seeing that happening.
-- http://www.ezwoodshop.com
View huff's profile
huff
2828 posts in 3282 days
#12 posted 09-01-2012 03:11 PM
I like the screws from Mcfeelys; Post #1, I believe Nighttripper left the link. They handle about any type screw you would ever need. Service is good, quality is great. They give a good description of each type screw also. You can go on line and order one of their cataloges or they will send one with your first order.
-- John @ http://www.thehuffordfurnituregroup.com
