Advice on how to make a specific dado cut
Forum topic by Jasoninsacramento posted 265 days ago 848 views 0 times favorited 16 replies Add to Favorites Watch
View Jasoninsacramento's profile
Jasoninsacramento
43 posts in 320 days
265 days ago
Topic tags/keywords: dado milling tablesaw router zebrawood question
I’d love some input on this one. I’ve been racking my brain for a way to do with without just nibbling away at it with my table saw.
I’m making a set if sushi plates for my father. I have a design in mind, but I can’t quite figure it out!
I need to cut two an angled dados into the bottom of the plate – at a 12 degree angle. The work piece is 10” by 6” and the two dados in each plate will eventually hold wooden runners that are serving as legs. When you look at the plate from the front, you’ll see the profile of the two legs each in the shape of a parallelogram. I only need to go about 3/4 of an inch deep, but the trick is that I want the bottom of the dado (closest to the top of the plate) to be parallel with the top of the plate. I hope that makes sense!
If I just put my dado blade in the table saw and tilted to 12 degrees, the top of the dado would be angled rather than parallel to the top of the plate. As I said, I could nibble away at it with a regular TS blade, but there has to be a better way. :-). Maybe?
Btw, I’m working with my tablesaw and a router table.
What do y’all think? Thanks, in advance for your help!
Jason
16 replies so far
View Milo's profile
Milo
802 posts in 1488 days
#1 posted 265 days ago
I’ve got it.
Take the board you are going to make the plate out of, 10” x 6”. Joint and and plane it flat. After it’s it’s parallel, NOW make your dado cuts before you do anything else.. After that, use a horizontal table router table to cut your 12 degree bottom angle. Kinda like a raised panel.
Now, if the bottom is not like and upside down raised panel, but flat, and you want the 12 degree dado’s, try this. Take your board and pencil your dados on the end. Set up you table saw to the proper depth. Get your protractor or whatever your making the angle with.
Place your plate board against the fence. Now, with a scrap piece of 1/4” board, raise the plate board, slip the scrap under the plate, and adjust it until the plate is at 12 degrees. Mark the place the scrap would be. Now, use some double sided sticky tape to secure the scrap in place. Make your dado cut. The scrap will of course need to be parallel to the blade, and long enough to reach past the blade.
Does that make sense? Let me know if it doesn’t and I’ll try again! ;)
Milo
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View cabmaker's profile
cabmaker
1029 posts in 978 days
#2 posted 265 days ago
Im not quite getting a grip on your description but could you do the dado with an angle adj. base router ? Or just stick with red meat.?BTW I dont think a dado is what your after is it ?
View rance's profile
rance
3856 posts in 1329 days
#3 posted 265 days ago
Me neither. A picture would be worth 1000, no 10,000 words in this case.
Actually, I re-read it again and think I understand part of it. I would tackle it with a glue-up. Bottom is then perfectly flat with no tool marks. Like this:
View RiverWood's profile
RiverWood
107 posts in 929 days
#4 posted 265 days ago
If you go with a common dovetail angle (14 degrees maybe) You can cut one side with a saw blade cut then finish the dado width with a dovetail bit on the router table
-- My favorite projects were firewood bound
dennis mitchell
3994 posts in 2483 days
#5 posted 265 days ago
Nibble….away. It won’t take long.
View Alexandre's profile
Alexandre
1417 posts in 360 days
#6 posted 265 days ago
You can make a “Stumpy” horizontal router table…. It is definitly worth the price for the plans and when you’re done, you can still make a ton of stuff with it.
-- My terrible signature...
View NormG's profile
NormG
2579 posts in 1173 days
#7 posted 265 days ago
I am glad someone had the answer, let us know how it works out
-- Norman
View FirehouseWoodworking's profile
568 posts in 1442 days
#8 posted 265 days ago
The good folks above have already given you a number of good, effective techniques. I’ll give you one more.
Cut the dado at the 12 degree angle with either the table saw or router table. You can make a carrier jig to hold the wood at the 12 degree angle on the router table or tilt the dado blade on the table saw.
Then cut a triangular cross section (12 degree angle) length of wood that will fit in the bottom of each dado and glue it in. Just another thought.
Cheers!
-- Dave; Lansing, Kansas
View Howie's profile
Howie
2449 posts in 1092 days
#9 posted 265 days ago
Nibble it out with the TS and finish with a sharp chisel.
-- Don't rollerskate in a buffalo herd
View Cosmicsniper's profile
Cosmicsniper
2148 posts in 1327 days
#10 posted 265 days ago
Nice solution, Riverwood!
-- jay, www.allaboutastro.com
rance
#11 posted 265 days ago
I also like Firehouse’s and riverwood’s methods.
Jasoninsacramento
#12 posted 265 days ago
@ Jonathan – that’s exactly what I meant. Sorry, folks, been away from the computer for the evening…I’ll read up right now!
Jasoninsacramento
#13 posted 265 days ago
Thanks everyone! I love Riverwood’s solution…seems easiest. And Thanks Jonathan for the graphic. Perfect@ I’ll post pictures when I’m done!
View MrRon's profile
MrRon
1578 posts in 1412 days
#14 posted 264 days ago
I think the nibble and chisel method is the best; maybe not the quickest, but less chance of screwing up.
Jasoninsacramento
#15 posted 262 days ago
Riverwood & Jonathan’s suggestion worked perfectly! Yay! Thanks, everyone!
