Stumped By A Kid
Forum topic by ChuckV posted 266 days ago 1087 views 0 times favorited 32 replies Add to Favorites Watch
View ChuckV's profile
ChuckV
1752 posts in 1697 days
266 days ago
My 8-year-old son was watching me lightly pare with a chisel today. He asked me, “Why do the shavings curl up like that?” I really don’t have a good answer, and “It’s the same as with the shavings from a plane” isn’t much of an explanation. I can imagine this happening if the fibers on one side of the cutoff piece are more intact and exerting more force, but I don’t see clearly what the cause it.
I’m probably missing something simple.
- Thanks
-- "Too much hurry ruins the body. I'll sit easy … fan the spark" - I. Anderson
32 replies so far
View PurpLev's profile
PurpLev
7753 posts in 1818 days
#1 posted 266 days ago
the blade is slicing the fibers, and the movement of the blade forward is breaking and pushing them upwards (almost perpendicular to the bevel angle) the thinner the shaving, the less “breakage” and the more of a natural ‘curl’ is formed to the eye.
View hhhopks's profile
hhhopks
546 posts in 547 days
#2 posted 266 days ago
If true, I should able to uncurl it make it stay that way. Right? But that’s not the case.
It is an interesting question.
I would need a more detailed sciencetific explanation.
Sorry, I am not offering any. : _(
-- I'll be a woodworker when I grow up. HHHOPKS
4886 posts in 1817 days
#3 posted 266 days ago
The wood is compressed by the cut and because the chisel
bevel forces it to go one way, a little extra compression and
breakage occurs on the opposite side, causing the curl.
14858 posts in 2388 days
#4 posted 266 days ago
I would say it has more to do with stretching the fibers as you cut.
Did you ever see a person gift wrap a package and curl the ribbon by running one side of it against the sharp edge of the scissors? Same principle.
ChuckV
#5 posted 266 days ago
hhhopks,
That is exactly what my son and I talked about. The curl is permanent.
Also, what determines the direction of the curling, i.e., clockwise or counterclockwise? Maybe it has to do with the direction that the blade is skewed. If I were in my shop now, I would try skewing in both directions as well as trying to cut with no skew and see if this affects the direction of the corkscrew. I would expect just a coil like a clock spring when cutting without a skew.
View rance's profile
rance
3856 posts in 1330 days
#6 posted 266 days ago
I think it has to do with the Coriolis Effect. Curls will turn the opposite direction south of the equator.
View daltxguy's profile
daltxguy
1323 posts in 2084 days
#7 posted 266 days ago
I’m going with a combination answer – stretching of the fibers from the blade – Charlie’s explanation is an easy way to explain it to an 8 yo. – but if the cut is reasonably thick, then I think there must be some compression too on the top side of the shaving caused by the plane ( or chisel) blade pushing the shaving away from the plane of the surface.
If you take an axe to a tree at an angle, the chip which comes out will be slightly curled – that’s not likely from stretching the fibers.
If you plane endgrain, does it curl?
-- If you can't joint it, bead it!
ChuckV
#8 posted 266 days ago
rance,
That sounds right. Now I remember learning all about this in Earth Science in the 8th grade.
I hope that the Curiosity Rover will be doing some wood curling tests on Mars.
#9 posted 266 days ago
Chuck, this is what happens when guys our age have young kids.
I’m glad mine are 26 and 23…. they already have ALLthe answers!
View Porchfish's profile
Porchfish
472 posts in 702 days
#10 posted 265 days ago
Wood Fairies !
-- some men see things that are and wonder why, I dream of things that never were and ask why not .... rfk
View Bill White's profile
Bill White
2604 posts in 2130 days
#11 posted 265 days ago
Smart alec kid. Ban him from the shop. Shouldn’t be askin’ questions that the old man can’t answer.
Just jokin’ of course.
Bill
-- bill@magraphics.us
View ADHDan's profile
ADHDan
105 posts in 278 days
#12 posted 265 days ago
My chisel shavings never curl. They just come out straight as a board.
Clearly the answer is: you are a wizard.
-- Dan in Minneapolis, woodworking since 11/11.
View Surfside's profile
Surfside
2287 posts in 343 days
#13 posted 265 days ago
Chuck, why don’t you tell your son, “It’s natural son. Things happen on their own and they just happen. There’s no need to question them. Just like your hair, it goes curly as it grows longer.” Pretty effective for me. lol
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
ChuckV
#14 posted 265 days ago
Sometimes I think I should be more like the Dad in Calvin and Hobbes
Surfside
#15 posted 265 days ago
Not if you don’t have a smart kid like that.
showing 1 through 15 of 32 replies
