| Forum topic by daveintexas | posted 128 days ago | 246 views | 0 times favorited | 11 replies | ![]() |
128 days ago |
Topic tags/keywords: frame panel curved |
128 days ago |
Hi Dave; This is really something. I was looking for pictures to post earlier on using yellow glue to veneer a project with. I couldn’t find it, but I did come across a couple photos from about twenty eight years ago, which had curved raised panels. My buddy Bruce and I built this. Don’t laugh at our pictures, we do look a LITTLE younger. I’ll see if I can find them again, and post them. The curved stiles need to be cut on the band saw. Since the cutter set we were using couldn’t be run to the ends of the stiles, we stopped the profiles short of the rails and brought them to the rails with carving tools. We made a jig to allow us to use the shaper, actually a router table, to shape them. Depending on the panel you are using, meaning if they’re veneered, you can use bendy board for the curved panels. The curve really doesn’t look that tight to require anything special, so even regular cabinet plywood should co-operate, if it isn’t too thick. If they were to give you some trouble you could steam them a little over a tea pot, but I doubt that’s necessary. I hope this helps. Any questions, let me know. I’ll go find those pictures now and post them. Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
128 days ago |
Okay Dave, I found ‘em. The ends, being raised panel presented some challenges, but we pulled it off. This was the first cabinet project Bruce and I worked on together. Looking at my picture, it amazes me that anyone would hire me to do a half million dollar home renovation for them. I must have been a good talker! I don’t want to hear any LAUGHING. Just ooh’s and aah’s on the hope chest! Don’t make me come over there!!! ![]() ![]() ![]() Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
128 days ago |
Lee- -- MISSION FURNITURE-My mission is to build furniture |
128 days ago |
Hi Dave; I hope that wasn’t a wise crack. lol Did the information help at all? Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
128 days ago |
I built some serpentine-curved doors a while back. The The vertical frame parts were easy to do. I cut grooves with Here’s where it complicated. The horizontal frame parts were The parts were shaped with a template on a router table. The template was used to make the grooves in the curved I shaped the 1/4” roundover in the curved parts on the router I left about 2” excess on the end of the pieces. I marked out the The cut the 1/4” rounded-over profile back at a 45 degree angle on Then I put the doors together. -- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online businesses - http://COPYMATCH.COM |
128 days ago |
Thanks to Lee and Loren- Thanks again- -- MISSION FURNITURE-My mission is to build furniture |
127 days ago |
I’ve started a blog on curved raised panel doors, haven’t got very far with it yet but I’ll be covering what you want to know. I’m going to try and and to it tonight some time. -- Les, Wichita, Ks. (I'd rather be covered in saw dust!) |
127 days ago |
Thanks Les- Dave -- MISSION FURNITURE-My mission is to build furniture |
126 days ago |
Dave, First of all, if at all possible in your design, I recommend making your stiles go from top to bottom, rather than the rails going all the way across. First of all, it’s a bit more traditional and easier to “faire” the rails into the stiles. I would use a router table with a curved guide clamped to the table. I have a picture of how I did the stub tenons on the curved panels for the drum table on my website. Although it is a stub tenon, rather than a groove, it will work the same. Here is a pic;
As I said, this is set to cut a rabbet on each side of the curved panel. But you would set up a straight bit and have it spaced from the curved guide template to cut your groove in the center of your curved rails. I used a 3/4” mdf template / fence to cut these 18” tall curved panels, but you could even double up your guide and for a much narrower rail it would be easy. Of course your guide must match your curved rail in radius. How are you going to make your curved rails and panels? Bent lams, I’ll bet? -- John, Chisel and Bit Custom Crafted Furniture, www.chiselandbit.com |
126 days ago |
Thanks for the reply John- Thanks for the help, and I am looking forward to posts of your next project. Dave -- MISSION FURNITURE-My mission is to build furniture |
126 days ago |
Since your curve isn’t dramatic I would suggest you Just make the frame and cut a rabbet in the front I’m suggesting applied moldings because I don’t -- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online businesses - http://COPYMATCH.COM |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1363 |
| Become a sponsor |
1809 |
| Become a sponsor |
124 |
| Become a sponsor |
378 |
| Become a sponsor |
111 |
| Become a sponsor |
Woodworking Trade & Swap
252 |
| Become a sponsor |
Coffee Lounge
1019 |
| Become a sponsor |
LumberJocks.com Site Feedback
286 |
