Best wood to use for lathe practice ?
Forum topic by SuburbanDon posted 269 days ago 1194 views 0 times favorited 22 replies Add to Favorites Watch
View SuburbanDon's profile
SuburbanDon
407 posts in 1166 days
269 days ago
Hi, A friend gave me a low cost wood lathe. I wanted to do some practicing on it. Can somebody recommend an inexpensive and forgiving wood type to use ? Thanks.
-- --- It's the little tools that get you ---
22 replies so far
View Nick_R's profile
Nick_R
70 posts in 321 days
#1 posted 269 days ago
Pine is cheap and plentiful. What kind of chisels do you have? I have a midi lathe and it didn’t matter what kind of wood I used, my chisels were DULL. So keep em sharp and start with soft wood. Also make sure the grain runs horizontal.
-- Hope for the best but plan for the worst. - 7 finger Nick :)
View BigYin's profile
BigYin
170 posts in 588 days
#2 posted 269 days ago
Free wood is the best to practice with.
look out for tree surgeons at work, dont be shy, ask for some timber
in residential areas ornamental trees can produce some beautiful wood
-- ... Never Apologise For Being Right ...
View Loren's profile
4898 posts in 1820 days
#3 posted 269 days ago
Tree limbs. Plentiful and available in interesting species.
Pine is pretty soft so you’ll learn some things about cutting
vs. scraping when turning it. Hard woods tolerate scraping
better and it becomes possible to fool yourself into thinking
you are developing more turning skill than you are with them.
SuburbanDon
#4 posted 269 days ago
Thanks for the input. The lathe came from Harbor Freight so the tools can’t be very good. But for my purposes it will have to do for now.
View TerryDowning's profile
TerryDowning
126 posts in 289 days
#5 posted 269 days ago
I’ve seen surprising data regarding the HF lathe chisels. They will do just fine and hold an edge well.
HF lathes are made in the same Chinese plant as many “top” names and often times parts are interchangeable.
Pine is a great material for learning on although the only thing forgiving about it is the cost. If you can shear cut pine cleanly so it does not require sanding or minimal sanding, then you have mastered shear cutting.
It will catch due to its open grain and soft nature. Sharp tools and proper technique are essential.
The most important lathe skill I have learned is sharpening!! Sharp tools make all the difference.
-- - Terry
View lumberjoe's profile
lumberjoe
2401 posts in 420 days
#6 posted 269 days ago
I have the HF chisels and did a review on them http://lumberjocks.com/reviews/product/2897. I really like them. I have not been turning for too long, but I learned an important lesson already: If you cannot sharpen your turning tools, you are going to have a bad time. Do some research on keeping your tools sharp. You will need to sharpen them a lot more often than you think. I had a lot of maple scraps that I practiced on. I think that turns quite well. I’m glad I didn’t learn on pine. As Terry mentioned it catches really easy. I wanted to play with some other lathe tools (skews, parting tools) so I chucked up a 2×4 scrap. It actually looked really cool when I was done with it. I found it was a lot more difficult to turn than hardwood though. Your results my vary.
-- http://www.etsy.com/shop/KandJWoodCrafts
View crank49's profile
crank49
2291 posts in 1143 days
#7 posted 269 days ago
Dan said, ”from Harbor Freight so the tools can’t be very good”
I ressemble that remark. My lathe and tools came from HF and they are fine thank you ;^)
Seriously, they do sell a couple of decent lathes and they sell some quality challenged tools as well.
Depends which one you got.
But, In my opinion it doesn’t have to be a $1000 setup to learn on and see if you like turning.
The lathe tools they sell that are HSS have natural finished, light colored handles and come in a wooden box.
I turned my first piece, a baby baseball bat, about 12” long, from Fir, because that’s what I had laying around.
Not the best choice of wood. Fuzzes up if you try to scrap it, had to learn the skew right away.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
SuburbanDon
#8 posted 269 days ago
OK I stand corrected on HF chisels. And that’s good news. I will have to look for a video on how to sharpen a gouge. Thanks everybody for all of the responses.
View derosa's profile
derosa
1472 posts in 1007 days
#9 posted 269 days ago
Best wood is any cut-offs that are sitting in your scrap pile. I have been finding that even hard woods aren’t too difficult to learn on and there is no concern about screwing up scrap. Biggest advice is get the face mask and a dust mask. It is an obvious thing that a lathe will produce a lot of dust but I was very surprised by just how much it really makes the first time. I also found that if I keep my bench grinder right next to the lathe that I’m more inclined to actually use it every time the tools start to seem dull. Picked up a fairly heavy stand for the grinder at HF for 30.00/
-- --Rev. Russ in NY-- A posse ad esse
View NewEnglandsWoodWorks's profile
114 posts in 773 days
#10 posted 269 days ago
Pine.
-- Brett Miner www.NewEnglandsWoodWorking.com
SuburbanDon
#11 posted 269 days ago
So it sounds like using only a grinder on chisels is typical ?
View TheDane's profile
TheDane
2676 posts in 1835 days
#12 posted 269 days ago
For practice on spindles, I ripped some 2×4 cutoffs anywhere from 8” to 14” in length in two.
—Gerry
BigYin
#13 posted 269 days ago
how to sharpen from youtube http://www.youtube.com/watch?v=OPhRk8g1iuA
sharpening jig http://www.youtube.com/watch?v=5i9RDnJHz9g&feature=related
using a skew http://www.youtube.com/watch?v=cQTo1pAIpQ4&feature=related
1. wear dust mask
2. wear safety glasses / goggles / facemask
3. keep tools sharp
4. enjoy
View Camero68's profile
Camero68
64 posts in 353 days
#14 posted 268 days ago
Pine. Since it is especially soft, it is easier to manipulate. Best of luck.
View AUBrian's profile
AUBrian
70 posts in 843 days
#15 posted 268 days ago
Pine is good because it’s soft. It requires sharp tools to cut well, plus it’s cheap/free. I also use branches from trees in the yard that I trim, firewood, storm cleanup debris, and like someone mentioned, make friends with a tree service, and you’ll never be wanting. Most times, people want them to clear the debris, and the less they have to haul away, the better. That being said, make sure you don’t get in their way or keep them waiting on you (They won’t). Don’t hesitate to walk right up when you see some working and ask if you could have a few slices from the tree…the worst they can say is no.
