Lubricant for TS blade height and bevel adjustment gears?
Forum topic by tool_junkie posted 269 days ago 662 views 0 times favorited 13 replies Add to Favorites Watch
View tool_junkie's profile
tool_junkie
125 posts in 701 days
269 days ago
Hi Guys,
It is time to lubricate the height and bevel adjustment gears on my Craftsman table saw (since I am going to put a new bevel adjustment hand wheel on). I have used the following dry lubricant in the past:
Blaster 9.3 oz. Dry Lube with PTFE Lubricant
http://www.homedepot.com/h_d1/N-5yc1v/R-202532762/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=dry+lubricant&storeId=10051#.UDz69aMcDGg
When I was inspecting the gears over the weekend, I noticed that the lubricant had hardened a bit and that makes me think I probably used the wrong type of lube.
So, the question is, has anybody used this lube before for the height and bevel gears and is it normal for it to harden (not rock solid though) over time?
Is there a better lube that can be applied?
Thanks!
-- Looking for a good quality Drill Press and a Cabinet Saw for cheap!
13 replies so far
View MrUnix's profile
MrUnix
257 posts in 371 days
#1 posted 269 days ago
I use paraffin.. works great and doesn’t attract dust. Others will chime in with their preferred lube shortly :)
-- Brad in FL - To be old and wise, you must first be young and stupid
View mcase's profile
mcase
397 posts in 1301 days
#2 posted 269 days ago
Sawstop recommended basic auto bearing lube. It certainly works better than the lithium grease some have recommended. But, it certainly attracts dust. I might try paraffin. Any application tips Mr Unix?
View bondogaposis's profile (online now)
bondogaposis
1254 posts in 523 days
#3 posted 269 days ago
I like Rem oil. It is a very light gun oil that has Teflon and rust inhibitors in it. Available at just about any sporting goods store.
-- Bondo Gaposis
View Tedstor's profile
Tedstor
929 posts in 805 days
#4 posted 269 days ago
I’ve found motorcycle chain lube to work well. DuPont dry lube is also highly regarded. However these products also dry to a white haze. IMO, the dried lubricant does no harm to the machine, and prevents saw dust build-up. Pretty much any type of wet lubricant, such as bearing grease, is messy to work with and attracts saw dust.
Bottom line is that the product you already applied sounds aok to me.
View NiteWalker's profile
NiteWalker
1482 posts in 749 days
#5 posted 269 days ago
Paste wax. I use it for the top too.
I apply it with a tooth brush I got from the dollar store for $1 for a can of 8.
View Bill White's profile
Bill White
2608 posts in 2132 days
#6 posted 269 days ago
I’ve started using DuPont “Multi-Use” dry lube with Teflon. So far-so good. Got it at the blue borg.
Bill
-- bill@magraphics.us
MrUnix
#7 posted 269 days ago
However you can get it on there!! :)
On some stuff, you can just take a bar of it and rub it on then buff.. you can also make various forms by adding it to mineral spirits, from a paste to a liquid. I keep a masons jar of wax solution around at all times so I can dunk nuts and bolts into it or dab a little on a rag and apply that way. Once the mineral spirits evaporate you are left with a nice thin film of wax. If I need it a little bit thicker, I just throw it in the fridge for a couple of minutes and it turns into a semi-paste (the saturation point of the mineral spirits with wax changes with temperature). There are a lot of different ways to do it, this just happens to be the one I use and it seems to work pretty well for me.
The above is what it looks like at room temp.. about 2 1/2 ounces of paraffin dissolved in about 8 ounces of mineral spirits. If you let it cool just a couple degrees, you can see how it starts turning into a paste:
View 47phord's profile
47phord
136 posts in 409 days
#8 posted 269 days ago
Dry Lube is called Dry Lube because it is DRY-which is why it looks that way. It is usually moly (molybdenum disulfide for you technical types) or sometimes graphite suspended in a wet carrier(usually mineral spirits) that evaporates shortly after application making it ideal for lubricating stuff in dirty/dusty environments (like the inside of a tablesaw for instance). The drawback to using it is it tends to wear off quickly, requiring more frequent reapplications, but it won’t attract any gunk floating around in the air. Sorry if that sounded like a lecture, I used to work in the lubricants industry and all that technical crap is still rattling around in my head…
To answer your question, I’d stay the course with the dry lube. If things are getting hard to move, just hit it with another squirt from the can.
View johnintecumseh's profile
johnintecumseh
90 posts in 1589 days
#9 posted 269 days ago
Hey Tool Junkie the best lube you can use in these situations is Bostich Blue in a spray can . a good clean first , spray, dust will not stick . keep smiling John
-- retired and smiling
View ajosephg's profile
ajosephg
1723 posts in 1733 days
#10 posted 269 days ago
CRC Industrial Moly Lube works well for me. It comes in an aerosol can, and sprays on dry.
-- Joe
View CessnaPilotBarry's profile
CessnaPilotBarry
602 posts in 282 days
#11 posted 269 days ago
I like dry bicycle chain lubes and the generic brethren…
White Lightning or Pro Gold bicycle chain lube works great, as well as all the “drip apply” dry lubes Lowes and HD are selling these days.
Bicycle chains have similar requirements, low speed, low temp, operation, and you don’t want something wet to attract junk.
-- It's all good, if it's wood...
View Arlin Eastman's profile
Arlin Eastman
1312 posts in 733 days
#12 posted 269 days ago
Bill
+1 on what Bill said
Arlin
-- It is always the right time, to do the right thing. Lovinghandsmemoryboxs.com
tool_junkie
#13 posted 268 days ago
Guys,
Thanks for all the valuable feedback. I think I will spray the gears with a fresh coat of what I already got and will then monitor how long it lasts and switch if necessary.
Thanks!
