Miter Saw extensions, both sides or just one?
Forum topic by cagenuts posted 08-28-2012 02:24 PM 2653 views 0 times favorited 6 replies Add to Favorites Watch
View cagenuts's profile
cagenuts
36 posts in 2459 days
08-28-2012 02:24 PM
Topic tags/keywords: miter saw incra track
Morning folks.
I’ve bought two INCRA Track (52” and 36”) to increase the accurate measuring capacity of my Miter Saw. I was originally going to use them as depicted in this picture.
Having gone through the very expensive exercise of importing them, I am now thinking about using the 36” on my Drill Press table like this.
Long story short, could I essentially make do with just one extension like this?
I figure that you are either cutting a long board to an exact length or cutting a short length off a long board.
Am I missing anything obvious?
-- Weekend Wood Wrecker
View Mainiac Matt 's profile
Mainiac Matt
8615 posts in 2567 days
#1 posted 08-28-2012 02:38 PM
I think having the track and stop on one side of your miter saw will cover >90% of your needs.
-- I yam what I yam and that's all what I yam
View SnowyRiver's profile
SnowyRiver
51457 posts in 3719 days
#2 posted 08-28-2012 02:43 PM
If you have the room, I would always extend both sides. Its always nice to have the support on both sides so you can make cuts without having the board extended way off the table.
-- Wayne - Plymouth MN
cagenuts
#3 posted 08-28-2012 02:45 PM
Wayne, I will have extensions on both sides, just the ability to measure on only one side. Does this make sense?
SnowyRiver
#4 posted 08-28-2012 02:50 PM
Yep…sure does….sorry, I misunderstood what you were trying to do. I would think it would be convienient to have the measure and stops on both sides. Not that you would have to, but it would make things quicker and easier.
View dlmckirdy's profile
dlmckirdy
199 posts in 3372 days
#5 posted 08-28-2012 03:04 PM
Although it would be convenient to have the tapes on both sides of the miter saw, I can see your point in using just one on the saw and one on the drill press. Because of the expense of importing the items, I think I would do it your way. Maybe later, if you are ordering/importing something else, you could include another tape system for the other side of the saw.
-- Doug, Bakersfield, CA - I measured twice, cut it twice, and it is still too short!
cagenuts
#6 posted 08-29-2012 11:50 AM
Thanks very much guys.
