rewiring hf dust collector to 220 volt
Forum topic by Cole Tallerman posted 265 days ago 450 views 0 times favorited 5 replies Add to Favorites Watch
View Cole Tallerman's profile
Cole Tallerman
357 posts in 352 days
265 days ago
Topic tags/keywords: 220
So I’ve never rewired a tool to 220v but I only have 2 spaces left in my sub panel and I need a new 220 volt outlet for a welder I just got. The plan is to use the same outlet for both the dust collector and the mig welder which means I have to switch the dust collector to 220v. What stuff do I need to get? should i have an electrician check my work? The little box with the wire running into it says “115 volt” will i need to replace this box? Anything helps including videos or web pages.
Thanks!
5 replies so far
View hhhopks's profile
hhhopks
546 posts in 545 days
#1 posted 265 days ago
To start, the fan motor of your dust collector need to be rated for 220 Volt.
When you get your replacement motor, you should able to follow the wiring instruction that comes with it.
Often there is a wire diagram on the motor or in the wire compartment/plate.
-- I'll be a woodworker when I grow up. HHHOPKS
Cole Tallerman
#2 posted 265 days ago
It is rated for 110 volt or it can be rewired to 220 volt
View MonteCristo's profile
MonteCristo
2060 posts in 356 days
#3 posted 265 days ago
If it’s not a dual voltage motor, you’re stuck on 110V. If it is, the wiring diagram will show the changes that need to be made.
View lunn's profile
lunn
130 posts in 476 days
#4 posted 265 days ago
Can’t change the voltage on the motor!! The breaker must be for a 220v. (the trip handles are pinned together) and proper amps for the welder. As for an extra 110 check the name of the breaker box. Check at a elect supply store. Many brands makes a piggy back breaker. Which gives you 2 breakers in the same space. Or if it’s a ITE, GE, Sometimes they’ll have breakers that take up 2 spaces about 1” wide. They can be replaced with 2 slimline breakes. A 2 for 1 swap. Either way is safe. Working on 440 3 phase while hot scares me !!!
-- What started as a hobbie is now a full time JOB!
View Howie's profile
Howie
2449 posts in 1090 days
#5 posted 265 days ago
You should probably call an electrician. Not being familiar with what you are doing could result in burning your shop/house down.
-- Don't rollerskate in a buffalo herd
