| Forum topic by andy81563 | posted 270 days ago | 361 views | 0 times favorited | 10 replies | ![]() |
270 days ago |
I have just purchased a Powermatic 160 planer. It was not hard wired in the previous location but plugged into the wall. Where it is located in my shop is too far from the outlet and an extension cord is needed. The problem is that the motor is a single phase, 5 hp, 110 volt variety and I have read this size motor could pull well over 50 amps. What size wiring and breaker should I use for this setup? |
10 replies so far
#1 posted 270 days ago |
You can rewire it to 230V and use a smaller wire size. depending on how far your machine is from the receptacle, I would consider hard wiring a new circuit to handle the new 40 amp breaker you’ll need for 115V but a 20 amp breaker at 230V would be easy to do and you could use 10/3 SJOO cable, capable of carrying 50amps per leg and available at any RV dealer for about $150 for 35’. -- Improvise.... Adapt...... Overcome! |
#2 posted 270 days ago |
I thought about rewiring the motor for 230V but it is an old motor and the wiring diagram is not very legible. I will try again looking at the motor to see if I can tell. |
#3 posted 270 days ago |
Download the PDF owners manual for the unit. It took me about 30 seconds to find it with Google using the phrase “Powermatic 160 planer” -- Improvise.... Adapt...... Overcome! |
#4 posted 268 days ago |
Well, I was wrong about the motor voltage. I is a 230 V. So, I have the electricity problem solved. Now, I need to figure out how to use the thing. I realize it needs a good bit of tune up, but it was running when I bought it. Can the cut depth be adjusted on this machine? I have the manual and it does not say anything about that adjustment. I know I seem really stupid but I guess I am just overlooking something. |
#5 posted 268 days ago |
Doesn’t the table move up/down when you crank one of the handles? That would be the depth of cut, raising the table would move the wood closer to the knives. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#6 posted 268 days ago |
The table does move up and down for different board thicknesses. The upper feed rollers limit the stock, though. It seems to me that if the upper rollers and cutterhead do not move independently up and down then the depth of cut can not be changed. |
#7 posted 268 days ago |
Nope, the table up/down is what does it. The planer should cut maybe 1/16” or so per each cut, then you crank the table up and remove the next 1/16”. With a 160, you can probably hog off more wood than that, maybe up to 1/8” or so, but generally lighter cuts are more satisfactory. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#8 posted 268 days ago |
Fred, you are right. I have it working fine now. It is obvious I have a lot to learn. |
#9 posted 268 days ago |
5 HP on 110V – I new something was fishy ! -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#10 posted 268 days ago |
The fishy part is my ignorance. I guess I will eventually learn. Ha! |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3554 |
15804 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
