Freud Thin Kerf Ultimate Plywood & Melamine - LU79R
Forum topic by sIKE posted 485 days ago 1041 views 0 times favorited 13 replies Add to Favorites Watch
View sIKE's profile
sIKE
1094 posts in 647 days
485 days ago
Topic tags/keywords: question miter saw blade
I am looking at a new blade for my Miter Saw after looking around this is the blade that is on top of my list. What does everyone thing about this blade. Pure crosscuts is all I am after and in reality 90° cuts are all I am after long term. I plan to do my mitering on the TS with a nice Miter Gauge and/or crosscut jigs/sleds….
3710 posts in 873 days
485 days ago
Hi sIKE;
The link didn’t work, but Freud does make good blades. I still stick to Forrest even though they’re a little pricey.
By now it just maybe a habit!
View GaryK's profile
GaryK
9521 posts in 882 days
485 days ago
Try this Lee:
http://www.freudtools.com/p-16-thin-kerf-ultimate-plywood-melamine.aspx
20603 posts in 715 days
485 days ago
Everything I have read on Freud suggests that they make a quality blade but I agree with Lee. I use all of the different Forrest blades on my saws and simply have not found a reason to switch to another manufacturer. But at one-half the cost of the Forrest blade this on may be worth looking into.
View sIKE's profile
sIKE
485 days ago
Thanks! I have ordered one, had a 15% off coupon to Rockler that was going to expire n the 31st so I went ahead and ordered one of these.
View steveosshop's profile
steveosshop
208 posts in 519 days
484 days ago
sIKE, you should post a review on the Freud blade. I would be interested to see what kind of quality the blades are.
-- Steve-o
View John Ormsby's profile
John Ormsby
503 posts in 630 days
484 days ago
I usually use an industrial, very thick, blade for the miter saw. A thin kerf blade will work for thin material, but will deflect a bit when trimming thicker stock. You might consider getting a thicker blade also for those thicker, heavier boards.
-- Oldworld, Fair Oaks, Ca
View sIKE's profile
sIKE
484 days ago
Thanks John that is what I was interested in hearing, Freud has the LU80R which is basically a standard kerf version of the same blade.
View DaveH's profile
DaveH
372 posts in 672 days
57 days ago
I use all Freud blades and love them. For plywood I use their blades that have an excellent rating for plywood use. My experience has been almost no tear out on plywood cross cuts. I use them on my 7.25 circular saw and 10 table saw.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
View knotscott's profile
knotscott
522 posts in 269 days
57 days ago
The LU79 is the thin kerf version of the LU80 (formerly the F810), which is an 80T Hi-ATB grind. The high bevel angle on the top of the tooth gives the Hi-ATB grind the lowest amount of tearout of any other grind, which makes it outstanding for crosscuts, plywood, melamine, veneers, etc. The downside of the high bevel angle is that it tends to abrade a little more rapidly than most grinds….keep it clean and it should stay sharp for quite a while for hobbyist uses.
The LU79 and LU80 are similar to the Forrest Duraline 80 tooth, the Infinity 010-080, and the Amana MB 10-800. I’ve tried the F810, Forrest 100T Duraline, and a similar Infinity 010-060 60T. All are exceptionally clean cutting, and anyone of those should serve in a similar fashion for the application you described.
View gerrym526's profile (online now)
gerrym526
134 posts in 702 days
55 days ago
I replaced the 60 tooth blade on my Hitachi SCMS with the Freud LU85R010 10-Inch 80 Tooth ATB Ultimate Cut-Off Saw Blade with 5/8-Inch Arbor and PermaShield Coating
The crosscuts are glass smooth, and it costs less than a Forrest (which I have on my TS and love). Makes a lot of powder quality sawdust, so use your dust collection behind the blade.
-- Gerry
3037 posts in 915 days
54 days ago
I’m about due for a couple of new blades here.
What are your thoughts on “thin kerf” blades now?
I have always avoided them in the past to help eliminate flutter.
knotscott
54 days ago
I’ve had a lot of success with high quality TK blades. They’re an excellent choice for smaller saws, not so much to save wood, but to save motor strain. A full kerf blade is 33% thicker and simply requires more power to get through the same cut. If you’ve got a true 3hp + cabinet saw, there’s less reason to use TK, unless that’s what you’ve already got or if you cut a lot of expensive exotic woods (then the savings can add up).
Modern TK designs are excellent and can cut as well as a comparable full kerf blade….a couple of magazines have stated pretty much the same thing recently. I’ll reiterate the importance of sticking with the higher quality blades… don’t expect a $16 junker from HD to consistently to justice to woodworking projects. $35-$40 tends to be about the starting point for higher end blades, and can easily hit the $100 mark. If you stick with the better Industrial Freuds, Forrest, Infinity, CMT, Leitz, Amana, DeWalt Precision Trim, you shouldn’t experience any flutter on a saw that’s running smoothly doing hobby level quantities. If your saw vibrates alot or has excess arbor runout, then a TK blade will tend to amplify the problem.
View sIKE's profile
sIKE
51 days ago
On the CMS/RAS I have TK blades and I have not had any issues what so ever. I have been extremely happy with both blades so far.
