Question regaring Power Twist V belts......
Forum topic by BiggKountry posted 271 days ago 725 views 0 times favorited 10 replies Add to Favorites Watch
View BiggKountry's profile
BiggKountry
18 posts in 837 days
271 days ago
I want to replace the belt on my bandsaw while I am tuning it up. Can I replaced the current ribbed v-belt with the Red Power Twist belt from Woodcraft?
Thanks,
Keith
10 replies so far
View MrUnix's profile
MrUnix
257 posts in 370 days
#1 posted 271 days ago
Sure.. the 4 footer is on sale now for $25.. or you can get a 5 footer at HF for $20.. I personally prefer kevlar belts for their low stretch and high strength but lots of people like the link belts as well.
-- Brad in FL - To be old and wise, you must first be young and stupid
View Dusty56's profile
Dusty56
10532 posts in 1860 days
#2 posted 271 days ago
I’ve had great results with the Harbor Freight green twist belts.
vibration before : http://www.youtube.com/watch?v=FdoR-FJmHeY
lack of vibration after : http://www.youtube.com/watch?v=7W6yQoMN-00
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
Dusty56
#3 posted 271 days ago
If you’re referring to this type of ribbed belt , it should already be a smooth ride…I don’t think a 1/2” twist v-belt would work in your pulleys properly.
View knotscott's profile
knotscott
4210 posts in 1547 days
#4 posted 271 days ago
You should replace the pulleys too if you’re going to use a link belt. Are you having issues with the current belt?
MrUnix
#5 posted 271 days ago
Eeekk! Yup to what Dusty sez.. if you have those type belts then the twist link belts won’t work.
BiggKountry
#6 posted 271 days ago
No…I wasn’t having issues, but I just replaced the tires and installed new bearing guides on the saw. Since I had to remove the wheels to install the tires, I figured I would replace the belt since everything was apart. I got the Grizzly saw from dad and it needed some TLC.
View Grandpa's profile
Grandpa
2381 posts in 847 days
#7 posted 271 days ago
The twist link belt is a V=belt replacement. It will not work with the ribbed pullies. A V-belt grips and powers through the side of the belt while the ribbed or serpentine belt pulls through the ribbed side or inside of the belt. Change the sheaves (pullies) and it should work. I don’t think you will gain much on your band saw by doing this but that is just what I think and not worth much more than that. In my opinion it wouldn’t be worth the cost to do this.
View MonteCristo's profile
MonteCristo
2061 posts in 360 days
#8 posted 270 days ago
I doubt the Red Power Twist belt is worth it on a bandsaw. I have found them really useful on a contractor’s table saw but otherwise not that big an improvement.
View Jonathan's profile
Jonathan
2568 posts in 1222 days
#9 posted 180 days ago
@ Dusty56,
Great comparison videos! You can hear the difference immediately upon you turning on the saw in the second video.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
View waho6o9's profile
waho6o9
2923 posts in 748 days
#10 posted 180 days ago
There was a vast improvement using the power twist
belts on my band saw, like night and day improvement.
Go for it.
