Ryobi DP121L drill press: can't tighten table
Forum topic by Brett posted 08-26-2012 11:24 PM 3723 views 0 times favorited 7 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2709 days
08-26-2012 11:24 PM
I have a Ryobi DP121L benchtop drill press. I like everything about it, except that I can’t tighten the table completely. The “table lock handle” locks the table in place vertically, but I can still move the table left and right easily.
Have any of you had this problem? What can I do to fix it?
UPDATE: I contacted Ryobi and described the problem. Apparently the collar (that goes around the column) is too loose, so they’re sending me a new one. Kudos to Ryobi.
-- More tools, fewer machines.
7 replies so far
View cutworm's profile
cutworm
1075 posts in 2820 days
#1 posted 08-27-2012 12:55 AM
I have the 10” drill press. Strange problem. I looked through my manual and didn’t see any type of adjustment for the lock. So far mine has done a great job.
-- Steve - "Never Give Up"
View Moron's profile
Moron
5032 posts in 3920 days
#2 posted 08-27-2012 02:28 AM
Ryobi is nothing more then a lesson in how to deplore all that never works as per the dreams you had before you bought it in that you dreamt it would work for the rest of your life.
Nothing but BAD memories and money wasted.
A “1 time shot” after which every successful pull on the cord is like winning a lottery
Moron
#3 posted 08-27-2012 02:37 AM
I think they make “JUNK”
They should have to PAY……taxes, if not only for the fact that their crap fills a landfill site first, but for the fact I have had to deal with dumping the crap off, my time, my gas money, by brakes, my truck expenses……..cuz when they make it, they laugh, knowing another fool like me, will fill a “finite” dump……with endless garbage.
Junk
Moron
#4 posted 08-27-2012 02:41 AM
sometimes its cheaper to rent
View ,'s profile
2387 posts in 3573 days
#5 posted 08-27-2012 03:44 AM
Yes, I am not a ryobi fan either, but I got mine practically free a couple years ago on CL. The drill press is the 10” bench top. Mine had the hinge drill attachment accessory installed when I purchased it so we were able to start using inserts hinges. The hinge attachment alone valued at 350.00.
So to answer your question, our press is using a shop made work top the is large and entirely mounted to the bench top. So that might be an option for you. But the way mine is set up, there is no raising and lowering the table as ours is stationary and fixed.
And our press is used a lot and so far the switch went bad and the handle spring has broken, but our press was used when I bought it and we use it a ton.
In truth though, we really need to decommissioned our ryobi press.
Brett
#6 posted 08-30-2012 03:38 PM
I contacted Ryobi and they believe the collar (which wraps around the column and is tightened by a locking lever) is too loose. They’re sending me a new collar ! Kudos to Ryobi.
Brett
#7 posted 09-10-2012 04:17 PM
It turns out that the threaded bolt that tightens the collar was getting stuck before the collar was tight. I used some WD-40 on the threads, and now the collar tightens up completely. Simple fix after all, but I wish the parts were better made to begin wth.
