| Forum topic by tool_junkie | posted 267 days ago | 1670 views | 0 times favorited | 16 replies | ![]() |
267 days ago |
I stripped the bevel adjustment plastic handwheel (part number 62250) on my Craftsman 113.29943 table saw. Although the original original is available from sears for $26 but since it is plastic, I really don’t want to buy something that will strip again. Sears suggests a substitute part # 62912 in place of the original for about the same price, but I am wondering if there is a cheaper alternate available? I need to use the saw in the interim, but without the handle i can’t change the bevel it is stuck at. Any idea how can I make the saw functional in the mean while? Thanks! -- Looking for a good quality Drill Press and a Cabinet Saw for cheap! |
16 replies so far
#1 posted 267 days ago |
Umm, how about the tool of a thousand uses?!?
Cheers, -- Brad in FL - To be old and wise, you must first be young and stupid |
#2 posted 267 days ago |
Only a thousand MrUnix ? Surely you jest ! It was a sad day when ViseGrip sold out to Irwin. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#3 posted 267 days ago |
I’ve repaired mine several times w/ epoxy, but when it goes I’ll make a wooden one. -- Bondo Gaposis |
#4 posted 267 days ago |
Mine just broke took. The lift wheel went as well. My plan is to make 2 new ones out of wood and epoxy the center metal piece in place. I’ll probably reuse the handle from the old ones. |
#5 posted 267 days ago |
Chuck on a cordless drill presto changeo power tilt or rise. Use low speed to fine adjust . worry about a wheel later !!!! -- What started as a hobbie is now a full time JOB! |
#6 posted 267 days ago |
You can check Ebay for a used metal hand wheel that fits. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#7 posted 266 days ago |
I have a 113.298762. I replaced my hand wheels with metal cranks from a Craftsman RAS. I got mine from off ebay from this guy (see below). They work fine. |
#8 posted 266 days ago |
I had the same problem with my Craftsman 8” Table Saw. I got a couple of nice metal hand wheels from Grizzly for less than 10.00 each, but I had to drill out the mounting holes and tap the threads for the set screws… They were an upgrade well worth doing. -- Woodmizer Lt 15, Belsaw 910, Delta Unisaw |
#9 posted 266 days ago |
Thanks for all the great info guys. I checked Grizzly’s website and they seem to be the cheapest around. They have the following wheel which I think will go well, but as scbolt6 said I would need to drill out the bore and tap for the set screw. http://www.grizzly.com/products/Cast-Iron-Handwheel-6-/H3189 How difficult of a job is it without a drill press? scbolt6: did you drill the hole all the way through or part way? Do you happen to have a picture of this setup handy? -- Looking for a good quality Drill Press and a Cabinet Saw for cheap! |
#10 posted 266 days ago |
Not to be too mother-like…...but don’t you think it’d be worth paying an extra $10-15 and getting a handwheel that’s already spec’d-out?? Are you sure the craftsman replacement part is plastic? When I went through this a few weeks ago, Sears referenced a metal replacement wheel. http://www.searspartsdirect.com/partsdirect/part-number/818526/0009/113 |
#11 posted 261 days ago |
Like I mentioned above, I am having the same problem. I was going to make a new handle out of wood (to save money) but the center was the only part that was damaged. I created a hub in Sketchup and cut it out on my CNC router. The center hub is hammer-in tight and is a hexagon so I don’t think it will slip. I still have to clean out the back of the wheel and epoxy the patch in but I think this will work. I’ll be doing this for both wheels (bevel & lift). Is your wheel the same as mine? |
#12 posted 258 days ago |
if it helps, here’s how it came out: |
#13 posted 256 days ago |
Hey Chuck, Sorry for the late reply. My handwheels are different than yours. The wheel is made of plastic and has a metallic collet that is held in the wheel with splines. This collet goes on the shaft and is held secure with a set screw.The main problem is that the plastic splines have stripped and the collet is somewhat free rotating inside the wheel. I looked at your CNC’d wheel insert, I really like your design. Did you use epoxy to bond the metallic part with the plastic wheel?
#14 posted 256 days ago |
Mine sounds exactly like yours. The metal collet in the donut I made was in the wheel and was held in with plastic splines. I cleaned out the splines with a roto zip, shown in the video to make room for the donut. The only thing I made was the wood donut with the hexagon cut out in the middle to hold the original hexagon-shaped collet. The metal collet fit tightly in the wood donut, no glue. I glued the donut to the plastic handle with hot glue. |
#15 posted 254 days ago |
i think I have one or 2 just like the ones you posted. PM me if you would want them. I parted out the saw some time ago. I’ll look and see if I have one left or both. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
| Forum | Topics |
Woodworking Skill Share
8788 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1527 |
3544 |
15758 |
Hand Tools
2032 |
Jigs & Fixtures
494 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6152 |
