Nuther Walnut Finishing Question.
Forum topic by oleCB posted 08-26-2012 12:30 AM 1213 views 0 times favorited 11 replies Add to Favorites Watch
View oleCB's profile
oleCB
77 posts in 2731 days
08-26-2012 12:30 AM
Topic tags/keywords: question walnut
I am working on a walnut project and it seems after putting a coat of ‘Zinsser Bullseye Seal Coat’ 100% wax free Shellac. The wood looks WAY darker than I want it to be.
This wood when first sanded, looks almost purple and outside in the sun sealed it looks good but, inside it is way to dark. I am using walnut endgrain blocks for the panels and I want the grains to stand out!
Should I bleach it some first or use another finish??
Thanks,
-- There was only one perfect carpenter... It wasn't me!
11 replies so far
View Moron's profile
Moron
5032 posts in 3943 days
#1 posted 08-26-2012 12:38 AM
got any pics ?
oleCB
#2 posted 08-26-2012 01:07 AM
Moron, I do in LJ. They were taken outside with the shellac and without. Check my project, ‘End Grain Blocks’
Moron
#3 posted 08-26-2012 01:19 AM
Without stripping it down, it is what it is. Personally I think it looks quite nice.
The only way you are going to get that to look “dry” , keeping the colour natural, is to the best of my knowledge and experience a very expensive journey.
Almost all wood darkens when finish is applied, and end grain more so.
You could try sanding it to the point of being polished……….right up to 400, maybe 600 grit paper or higher but the sanding would have to be even, consistent through out or you might get blotchy spots.
Again, its wood and its walnut………and I think it looks nice dark. Walnut is high in tannic acids and therefor oxidizes quickly so no matter what you use……….sooner or later, its going to get dark.
maybe some one else can offer better advice
Kind Regards
Gerald Thompson
1005 posts in 2285 days
#4 posted 08-26-2012 01:20 AM
Zinsser is for sealing. It is OK if you are going to top coat with somethings else. Try a one pound coat of amber shellac on a piece of scrap. It does well with walnut. I get my flakes from the Shellac Shack. They are fast and priced reasonably.
A good resource for finishing info is Homestead Finishing. Go to the site and register. There is the General Finishing Forum, Tips and Recipes area. Read these and your learning curve will be enhansed. One can ask questions in the forums that are particular to you situation. Good luck.
It should be noted I have no affiliation to the two aforementioned businesses.
-- Jerry
Gerald Thompson
#5 posted 08-26-2012 01:22 AM
Moron;
Walnut lightens over time.
-- Jerry
oleCB
#6 posted 08-26-2012 01:25 AM
Moron,
Thanks, I have plenty of walnut laying around. ;) So I can experiment some. Bout every time I cut into a log, I think man that stuff is pretty and it is. I just wanted the grain to pop out more inside the home with electric lighting. When up close it is fantastic, might be my eyes too. At 8 or more feet back it just looks chocolate colored to me.
Thanks Again,
ed
Moron
#7 posted 08-26-2012 01:27 AM
Gerald………..only if its in the sun
oleCB
#8 posted 08-26-2012 01:31 AM
Gerald,
Thanks, I will check them out!
I am leaning towards polyu for the top coatings.
ed
Moron
#9 posted 08-26-2012 01:38 AM
Ed, sometimes its better that our eyes fade with time
: )) <insert>
Moron
#10 posted 08-26-2012 01:45 AM
This is by far my favorite recipe for many reasons so to name a few
its easy, doesn’t require a degree in quantum physics
u can buy the ingredients anywhere
scratches, scuffs can be repaired easily
you dont need any special equipment
leaves a rich deep looking finish
easy to control the sheen
food friendly when cured
25% tongue oil / 25 % “real” high end marine varnish/ 50 % mineral spirits and 1 tsp japan dryer per quart
Gerald Thompson
#11 posted 08-29-2012 12:26 AM
Moron;
Here is what a huge lumber yard in Jacksonville, FL has on their site. Notice the last sentence.
Walnut has been a popular choice among woodworkers for many years. It machines and glues very well and is extremely stable. The majority of Walnut that is distributed has been steamed. This process blends the heartwood and sapwood in an effort to provide more uniformity in the color of the entire board. The heartwood is brown to black and the sapwood is basically white. Walnut is one of the few woods that actually lighten (instead of darken) with age.
-- Jerry
