Bosch 1617 switch solution?
Forum topic by ADHDan posted 08-25-2012 01:04 AM 5284 views 0 times favorited 13 replies Add to Favorites Watch
View ADHDan's profile
ADHDan
800 posts in 2284 days
08-25-2012 01:04 AM
Topic tags/keywords: question
I have the Bosch 1617 (fixed base) mounted in my Bosch router table. Based on many reviews, it appears this router model has a major problem with sawdust getting inside the on/off switch and damaging it. In order to prevent this, I used duct tape to secure some thick plastic wrap over the switch. Is there any reason this is a bad idea? It seems relatively airtight, I’m just not sure if this could conceivably cause damage to the router.
I also try to leave the router always on and use my table switch for power control, but I figured it couldn’t hurt to try to dust-seal it as well.
-- Dan in Minneapolis, woodworking since 11/11.
13 replies so far
View fussy's profile
fussy
980 posts in 3226 days
#1 posted 08-25-2012 02:46 AM
I’ve had an EVS 1617 for nearly 5 years and haven’t had a problem. What you’re doing can’t hurt. I have had issues with dust in my jointer switch, so I blew it out and left it open. No further problem.
Steve
View MonteCristo's profile
MonteCristo
2099 posts in 2364 days
#2 posted 08-25-2012 03:02 AM
I have 4 of these Bosch routers and have had no problems with the switches. I agree with fussy that coving the switch won’t harm anything. BTW the finish on the motor casing on one of my routers has oxydized. Don’t know why, as the others are fine (???)
ADHDan
#3 posted 08-25-2012 03:07 AM
It’s heartening to hear that none of your routers have had issues. I’m just basing my concern on the numerous Amazon reviews citing the power switch problem. Very glad to know my makeshift solution at least won’t hurt my router. Thanks!
View NiteWalker's profile
NiteWalker
2738 posts in 2752 days
#4 posted 08-25-2012 03:17 AM
IIRC the switch problem was fixed a while ago. A lemon still slips through, but all in all, the 1617 is a great router. The smoothest I’ve used.
If the switch does quit on you, compressed air has been known to fix it. Using an auxiliary table switch helps a lot too.
@MonteCristo; the original 1617’s had a magnesium body that corroded; this is probably what you’re experiencing. Bosch recalled the early 1617’s and replaced the housing with aluminum. Call bosch; they will make it right.
View mikema's profile
mikema
180 posts in 2762 days
#5 posted 08-25-2012 04:43 PM
Bosch is aware of the switch problem on the router and will send you a new switch for nothing. I have two 1617s one that does have the problematic switch. It actually is not at all difficult to clean out the sawdust, and can be done in about 15 minutes. You will need a torx head screw driver to take the top cover off, and a flat head screw driver (a small one) to pry the switch apart. Be very careful with this as there are several small parts including a spring that is easily lost.
-- Mike ---- Visit my woodworking blog: http://sawdustnewbie.com
MonteCristo
#6 posted 08-26-2012 03:38 AM
Thanks for the info NiteWalker ! I thought there must be something that had changed . . .
ADHDan
#7 posted 08-27-2012 04:41 PM
Thanks NiteWalker. I knew that at some point they switched from magnesium to aluminum, but I did not know that they fixed the power switch issue. I should be fine, I’m going to leave the plastic wrap over the switch just to be safe. Might as well; it doesn’t cause any hassle, since the router (a) is dedicated in the table, so I rarely take it out, and (b) is almost always left in the on position.
View skatefriday's profile
skatefriday
424 posts in 1658 days
#8 posted 02-15-2016 04:18 AM
My 1617 refused to turn on today. Took it apart and found no continuity in the switch with it in the on position. Took the switch itself apart and found it had enough sawdust inside to prevent the switch from engaging. Cleaned it out and it worked again.
This router was purchased in 2014, so apparently they still have the problem.
Note, don’t do what I did and take the motor out. Getting it back in between the brushes was a PITA.
View lateralus819's profile
lateralus819
2241 posts in 2065 days
#9 posted 02-15-2016 12:22 PM
My first bosch kit the release lever for the plunge broke. I accidentally let it snap back and the spring popped out. Had mine almost 4 years no problems.
View dhazelton's profile
dhazelton
2789 posts in 2472 days
#10 posted 02-15-2016 02:29 PM
If you have issues but your router is in a table and have a second front mounted switch, why not remove the routers switch entirely and just put a wire nut on the two leads?
runswithscissors
2874 posts in 2201 days
#11 posted 02-17-2016 12:30 AM
skatefriday: I’m wondering if you removed the brushes before trying to reassemble? I’m assuming it has externally accessible brushes, as I don’t have that model of router.
View MC's profile
MC
234 posts in 2523 days
#12 posted 02-17-2016 02:28 AM
I bought a 1617 in 2011, the switch went out on me after only a few hours of use. Bosch repaired under warranty and I have not had any problems since then.
skatefriday
#13 posted 02-20-2016 03:23 PM
Yes, I eventually figured out that I had to remove both brushes.
If I had a second front mounted switch I’d just leave the router’s switch
in the on position. But I don’t have a front mounted switch. It’s sitting
in a G1023RLW’s table and I just get my deep knee bend exercise in turning
it on and off.
