R4512 onboard storage and fold-up outfeed.
Forum topic by ADHDan posted 272 days ago 580 views 0 times favorited 2 replies Add to Favorites Watch
View ADHDan's profile
ADHDan
105 posts in 279 days
272 days ago
Topic tags/keywords: jig
Honestly, I almost considered this too obvious to warrant posting, but considering the popularity of the R4512 table saw I figured I might as well. The right rail of the R4512 has three pre-drilled holes which – combined with three long bolts – lend themselves to some very helpful onboard storage. I put bolts through those holes, locked them down with lock nuts and wingnuts, and use them to hang lightweight accessories. In a small shop, this keeps my pushsticks and paddles, eye-and-ear protection, miter gauge extension, and extra inserts close at hands.
I only use this for relatively lightweight items so I assume it’s not putting too much drag on the rail, but if anyone thinks this is a bad idea please let me know.
Also, I made a very cheap and easy outfeed extension table that folds up and down on hinged struts that rotate around dowels (no drilling into the saw cabinet/base required). More pictures of this are available in my projects.
-- Dan in Minneapolis, woodworking since 11/11.
2 replies so far
View Tennessee's profile
Tennessee
1089 posts in 685 days
#1 posted 272 days ago
I built the suggested table on mine, and then added a 36 X 36 inch bench the same height next to that. Kind of what you did on the left side. Between the two, I have a pretty big bench now at a great height on the right side. I have my fridge hiding under the 36X36…
-- Paul, Tennessee, http://www.tsunamiguitars.com
ADHDan
#2 posted 272 days ago
That sounds like a great setup. I got my outfeed table idea from a few similar designs on LJ, and tweaked the support/strut mechanism to make the project easier. Albeit the final result is less elegant, but I can live with that.
Edit: That side bench is on locking casters, so I can move it around as necessary. Sometimes it’s an extra outfeed table, sometimes it provides infeed support, sometimes it’s an extra assembly bench, and sometimes it holds a bunch of junk. I also store table saw jigs/sleds on a shelf underneath it, and I added a bunch of hooks (not pictured) to hang more accessories and my dado stack.
