Forum topic by a1Jim posted 08-24-2012 08:15 PM 3401 views 0 times favorited 62 replies Add to Favorites Watch
117032 posts in 3513 days
08-24-2012 08:15 PM
Topic tags/keywords: resource
I don’t know if there are other members that fight this kind of disorder but I discovered I had this disorder late in life. This disorder makes many things kind of upside down or backwards when reading or doing some projects. When building projects there are days that go perfectly well and other days that everything you do is amiss .
Yesterday I thought I would build a small cabinet to store some of my finishing products in,I’ve build hundreds of cabinets before. This is not a large cabinet only 30” tall and 20” deep by 24” wide . This was to be about a 20 minutes job . Since I was making it for the shop I thought I would try something I hadn’t tried before,just doing a 3/8” rabbit on the top and bottom of the sides and the top and bottom pieces of ply to interlock .This went fairly quick , I ripped the ply to size ,then routered the sides for adjustable self pins,rabbited the edges. I’m now into this project 15 minutes. I’m thinking a little glue shoot some brads into the over lapping joints then I’m ready for a back. I go to put it togehter and find I routered rabbits into the wrong sides of of the bottom, dang!!! ok it’s just a shop cabinet I’ll just glue a couple strips into the wrong rabbits and rabitt the other sides,RIGHT?-wrong I had this cabinet together and apart three times because the sides were unequal in size either in width or length. The last time I took it apart I left it in the shop and called it a day. The next day I did something I normally do checked all the measurements ,checked my routeing and did a dry fit. Still off on side,one more trim and another dry fit and It flew together quickly checked square,good to go. I now only have 4+ hours in making one lowly cabinet.
As a woodworking instructor what would I tell a student went wrong? I think in this case I broke most of the rules. #1 make a simple drawing #2 check your material for defects#3 double check all of your materials measurements(measure twice…) #4 don’t get in a hurry #5 check all of you milling (routing in this case) #6 always dry fit before gluing up your project # 7 use proven methods of joinery #8 Don’t forget the basics.
Can I blame this on dyslexia ? Probably not this time. :) But I truly have to fight this disorder and repair.remake or restart many projects because of it. The one thing it’s taught me is to keep on plugging along
I hope this lesson in humility can help others regardless of your level of experience.
-- wood crafting & classes
62 replies so far
View DocSavage45's profile
8489 posts in 2779 days
#1 posted 08-24-2012 08:26 PM
Diagnosis is OLD.DD LOL! Not dyslexia. The other thing I’ve added to this is Charles’ statement “Measure three times, then sneek up on it!” :-)
Old developmental disorder, just thought it up, but accurate, for me ‘cause I’m always forgetting the recent stuff.
Oh maybe you were referring to dementia. :-)
Oh yeah, be patient with you?
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Joe Lyddon's profile
Joe Lyddon
10012 posts in 3988 days
#2 posted 08-24-2012 08:35 PM
Welcome to the Old Age Club!
Nowadays one cannot rely on memory… you have to write everything down… and remember where you wrote it… in the shop one must dry fit, check, & dry fit again… just to be sure… Every move… every cut… must be rehearsed making sure nothing gets in the way of the cut… etc. etc.
Take your TIME!
DO NOT RUSH the job… no matter how SIMPLE you think it is…
Again, welcome to the club! LOL
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: ... My Small Gallery:"
View lysdexic's profile
5254 posts in 2559 days
#3 posted 08-24-2012 08:36 PM
A picture helps me keep things striahgt.
-- "It's only wood. Use it." - Smitty || Instagram - out_of_focus1.618
View Tennessee's profile
2828 posts in 2450 days
#4 posted 08-24-2012 08:37 PM
This kind of stuff happens to me. It is why I have four Starrett rulers lying around the shop, since I always misplace tools in a shop a little bigger than a one car garage. I bought a cheap HVLP spray gun today in Lowes, then got home and remembered that I had one in storage I’d never used. Duh…
We all have bad days, and as we get older, it is good to remember that our minds will not be as sharp, it becomes harder to take the cap off a new bottle of mountain dew, (no, they didn’t screw them on harder…), and sometimes, you just have to walk away and rest a while, let your mind catch up.
Today I was working on a really hard guitar, and had it hanging in my shop as the wipe on grain enhancer dried prior to shooting on the lacquer. Even though I know this position in my shop, all the guitars hang there sooner or later, sure as God made little green apples I managed to knock it off its hanger, and only pure luck let me catch it as it nicked one of my bench vices on the way down. Little sanding, another coat of grain enhancer, off we go again. But I left the shop, as I knew I was getting tired and more mistakes would certainly happen if I pushed forward.
Man’s just got to know his limitations…
View  woodshaver Tony C   's profile
woodshaver Tony C
5839 posts in 3289 days
#5 posted 08-24-2012 08:37 PM
I do stuff like that on every project!
But I’m old so I can get away with it!
-- St Augustine FL, Experience is the sum of our mistakes!
#6 posted 08-24-2012 08:53 PM
Thanks for your input guys very helpful,now I know I’m not the only guy pulling these kind of stunts.
Good save on the guitar Paul
View Jim Jakosh's profile
Jim Jakosh
20180 posts in 3041 days
#7 posted 08-24-2012 09:03 PM
That is when it is time to grab a beer and suspend work for that day and attack it tomorrow. I do it a lot. It must be a wood worker’s thing, but that makes you very good at recovery!!
Jim, you’re one of US!!!!!!!!!!!!!!!!!!.......................Jim
View SteveL's profile
167 posts in 3704 days
#8 posted 08-24-2012 09:07 PM
Yeah, not only am I getting older, I am lysdexic too. Too easily I’ll see a dimension like 32” and measure out 23”. Not only that, the second law of thermodynamics says that entropy always increases. Another name for entropy is disorder, and in my shop, disorder is always greater toward the end of a project. This makes it more likely that I’ll pick up the wrong part to cut or use a tool thinking it’s set for one cut, but it was actually set for another. I always buy enough stock to make 5 legs for a 4 leg table, and have more than one table top that was cut the wrong size just waiting for me to make another set of legs with shorter aprons.
Remember that for old woodworkers, there’s only a plane shaving or two between “dimension” and “dementia”!
-- SteveL
View Dallas's profile
3599 posts in 2423 days
#9 posted 08-24-2012 09:12 PM
Jim, I too am getting a bit long in the tooth.
I’ve learned that between your #4 and #5 rules I have to add #4a: lay everything together as well as possible and MARK the sides to be cut so if you see the marks it means you can safely cut!
I have a nice shop cabinet I made that is just beautiful, made from AC plywood.. too bad all the “A” sides are on the inside and all the “C” sides are visible!
View b2rtch's profile
4851 posts in 2984 days
#10 posted 08-24-2012 09:26 PM
When I do something like that I do not blame it on old age ( even if I am old ) but on little too much wine.
Jim do like me: blame the wine.
-- Bert
View teejk's profile
1215 posts in 2621 days
#11 posted 08-24-2012 09:36 PM
or do like me and not mention it to anybody…
View stefang's profile
15878 posts in 3270 days
#12 posted 08-24-2012 09:49 PM
You don’t have to be dyslexic to make those kind of mistakes Jim. We all do wrong stuff like you described. I think we are sometimes just not paying enough attention to the task at hand. It happens to everyone (especially me).
View Richard's profile
400 posts in 2627 days
#13 posted 08-24-2012 09:52 PM
I have found that when I am working from a plan or sketch I have to leave notes to myself as if I was writing for a dimwitted stranger. Even then I find myself challenging my own thought process, because I cannot remember how I arrived at that conclusion.
Don’t feel bad about it Jim, I think we have all had days when everything we touch seems to go sideways.
-- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain
View longgone's profile
5688 posts in 3244 days
#14 posted 08-24-2012 10:05 PM
That happens to me quite frequently since my brain bypass surgery.
#15 posted 08-24-2012 10:08 PM
“That happens to me quite frequently since my brain bypass surgery.”
I love it.
-- Bert
showing 1 through 15 of 62 replies
