Sketchup Followme Problem
Forum topic by bhack posted 08-24-2012 04:23 PM 1016 views 0 times favorited 1 reply Add to Favorites Watch
View bhack's profile
bhack
349 posts in 3590 days
08-24-2012 04:23 PM
Topic tags/keywords: question
I am attempting to use the followme tool to put an 1/8 roundover on a drawing and I get this
Why is there a hole left
-- Bill - If I knew GRANDKIDS were so much fun I would have had them first.
1 reply so far
View pintodeluxe's profile
pintodeluxe
5542 posts in 2683 days
#1 posted 08-24-2012 04:31 PM
Follow me is finicky. Try re-defining the top square, as well as the top edge of the box with the pencil tool. Then try the follow me again. It needs a well-defined path to follow, or it gets confused.
You didn’t do anything wrong, but often re-defining edges nearby will fix it.
Also, if follow me ever fails, undo it and try again. That is easier than trying to fix the problem manually.
