| Forum topic by SawdustMill | posted 129 days ago | 199 views | 0 times favorited | 15 replies | ![]() |
129 days ago |
Topic tags/keywords: bandsaw jig question drift I looked around yesterday and found a couple of plans for a bandsaw cutting jig, then made one. The problem is that the drift on my bandsaw is so bad that I only get about an inch before the blade is so bent that progress stops. I’m trying to cut about a 7” radius with a 1/4” blade. Any ideas how to make it work ? Perhaps my blade is too dull, or the tension not high enough ? |
129 days ago |
I’ll openly admit… I have very little experience with a bandsaw. But, instead of putting the center pin for the jig 90 degrees perpendicular from the blade (as the miter gauge runs), I wonder if you could find the angle of drift on your blade and then put the center pin 90 degrees to that angle. If you accomodate for the drift, then in theory it should work, right?... (lol… sounds like a longshot to me, but let me know if it works!) -- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17) |
129 days ago |
for circle cuts i like to us a jig saw to rough it out then i use a router with a straight bit to clean it up. i also use a circle jig with the router. -- Roper - master of sawdust- |
129 days ago |
First the blade is not tight enough. Try to tighten it with the guide pushed right up so you can plunk the blade. You can usually hear it vibrate an once you get a fairly striaght cut you can remember the tone it made. Bob -- A mind, like a home, is furnished by its owner |
129 days ago |
I had the same problem with my home made jig. After playing around, I discovered that I was positioning the jig incorrectly. I found that if I place the jig so that the pin (on which the work is rotated) is “even” with the leading edge of the teeth, I don’t get the binding. Previously, I had placed the pin at the approximate center of the blade. Lew |
129 days ago |
Lew, that’s a good thing to try, my pin is just behind the teeth, I’ll try moving it more in front of the teeth and see what happens |
129 days ago |
lew has it. The teeth need to be on the centerline of your pin. -- Gary, East TX -- The longest journey begins with a single step. |
129 days ago |
Set the upper guide as close as possible to the work… and set I’ll rough out circles on the bandsaw but for accurate ones I use -- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online businesses - http://COPYMATCH.COM |
129 days ago |
Update: Turns out I had the pin in line with the front of the teeth already. I tried moving a little in front, or behind, but the same thing happened. I’ll try tuning up the blade and tightening up the guides and see if that helps. If anything else I’ll just make a circle cutting jig for the router. I’d love to get the bandsaw jig working though, even if just for academic’s sake :) |
129 days ago |
Have you tried to do a straight cut? When you do do you have to angle the board to the right or left? Do you have a good blade of is it the one that came with the saw? Is the blade cutting toward the center of the circle or away from it. Try cutting it 1/8” larger first. Sounds like you might just have one screwed up blade. -- Gary, East TX -- The longest journey begins with a single step. |
129 days ago |
I have to twist the board clockwise looking down at the table. It pushes the blade to the left, away from the pin. The blade isn’t too old, but isn’t too new either. I think it’s also one that I’ve hit a pin nail or two with, so it’s about time for a new one anyway :) |
129 days ago |
One other thing to remember is that every size blade will have a minimum radius that it will cut. Yo might check to see if your blade is too wide for the circle you are trying to cut. This could really cause the blade to bind. -- Oldworld, Fair Oaks, Ca |
129 days ago |
That’s a good thought John, although a 1/4” blade should be able to cut a 7” radius pretty easily, or at least, it does when I freehand it :) |
128 days ago |
How about a picture of your set up? Lew |
128 days ago |
It sounds like your blade is dull. I cut bowl blanks on a daily basis up to 6” thick with a 3/8” blade w/3 tpi from 4” to 12” dia. -- ScB, OR http://stores.twoacreoutlet.com |
128 days ago |
what type of bandsaw are you using? if it’s a lower powered saw, say a bench top model you may need to slow the feed rate way down. If your pin is in line with the teeth of the blade and your guide bearings or blocks whichever you have, should help keep the blade from binding unless your saw is being stressed or is underpowered. -- Joey, Magee, Ms http://woodnwaresms.com |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1363 |
| Become a sponsor |
1809 |
| Become a sponsor |
124 |
| Become a sponsor |
379 |
| Become a sponsor |
111 |
| Become a sponsor |
Woodworking Trade & Swap
252 |
| Become a sponsor |
Coffee Lounge
1019 |
| Become a sponsor |
LumberJocks.com Site Feedback
286 |
