| Forum topic by b2rtch | posted 275 days ago | 1759 views | 0 times favorited | 61 replies | ![]() |
275 days ago |
Topic tags/keywords: question I have posted again and again about my Powermatic 60 jointer. I understand why I need my jointer tables need to be co-planar and flat and so on but when do we become obsessive/compulsive about it? What is acceptable and what is excessive and our quest for precision and accuracy? (by the way, I work in the pharmaceutical industry and I daily check our equipment with an accuracy with a few 1/10 of a thousand of an inch and/or a few tens of a thousand of gram) -- Bert |
61 replies so far
#1 posted 275 days ago |
Bert, My experience from this is that it does not need to be perfect. However it may seem that you are a little like me and we are perfectionists to a small degree. I do too put a dial indicator on my jointer blades when changing to get them within .001 of an inch, as i also do this to the tables. I also use this method align my tablesaw fence and miter track to the blade. My other friends tell me that i am way to picky when setting things up like this and as long as its close it will work fine. It would be perfectly fine without the precision we use but it would be the idea of knowing it was not close to perfect that would bug me to fix it. I hope this hepls a little. -- BN in Indiana |
#2 posted 275 days ago |
BrentNichols, I believe that this is a good explanation. -- Bert |
#3 posted 275 days ago |
I like it when things fit together well however, If you are asking if we need our tools dialed in percicesly the answer is no, precision can be had easily without exact error free tools. There are two different ways of working, machine precision and cutting to fit. Neither is right or wrong and they have different advantages. If you want every leg of a table the same length, you can dial in a saw to 1/100” a, measure, and cut each leg. Or you can cut one leg and use that to measure the others. In the first example, if your measurement is off between one leg and another, the variance is small, in the second because you are referencing off the piece, if you are off the variance is small. You can always go back and true them together, all four at the same time to ensure they are exactly the same length. If you watch Roy under hill, he may measure a piece at 6” and cut it, but when he goes to drill the center of it he doesn’t measure in 3”, he uses dividers. That way even if 6” is 6 1/8”, center is still center. Another example is door fronts. If you batch them out ahead of time then your measurements, on all the cuts, not just the drawer fronts, need to be percise because a 1/8” gap stands out. However, if you cut to the size you need, not the size you planned to need, the left drawer may be 1/8” wider than the right, but because you can cut it that way the gap between them will be uniform and unoticable. Obviously if you are making many identical cuts in a production shop and you are using very stable material, like mdf, then taking the tIme and expense to dual in your tools will be money well spent. A home hobbiest working with real wood can just work a bit differently. After all do you need 4 legs all exactly 23” long or do you need four legs about 23” long and exactly all the same length. The latter is far easier to achieve than the former. Most importantly is to work the way you enjoy. I am lucky enough not to own any machines made well enough to be dialed in with that kind of precision. When I do, I will probably try to get them exact as well. |
#4 posted 275 days ago |
CplStee, thank you for your very good answer, I truly like the way you explain the way you achieve what you want to achieve. -- Bert |
#5 posted 275 days ago |
To find what is acceptable for you in terms of accuracy, improve things until you aren’t apologizing for your work. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#6 posted 275 days ago |
With an Industrial Design background.. I was taught to do the best you can at every stage of the process, because you can not be perfect and all those small imperfections add up at the end… BUT that was for manufacturing mass producible items. To me, wood working is more like sculpture. I love being perfect, but i never let the tool determine the process nor the result. I gave up “perfection” a while ago, my tools move each season, blades go dull in the middle of a process… the wood a living material and if you don’t work with it… it will work against you. yet I work that there are places people see and feel and those places I make perfect, but the rest I just don’t stress about, so I say always do your best, and only focus on perfection for those few areas: joints and visible places. Thus I focus on beauty,, not perfection. Just take a serious look at Japanese cabinet makers… little spaces, uneven areas, plane marks.. they are about the beauty and efficiency… the perfection comes from the passion and repetition. The other thing is.. people are far more amazed YOU actually made something from scratch.. people are kinda blind to the imperfections we beat ourselves up for.. and I only fear other woodworkers scrutiny.. LOL. There is a book titled, the structural properties of materials.. and they have a chart that explains how much you can be off before it is a) actually visible to the client… b) or will fail from stresses. and you know.. we get a lot of wiggle room. -- ~ Eric P Jorgenson: Jorgenson Design |
#7 posted 275 days ago |
Lee and Eric, I truly appreciate what you write, I believe that these are good lessons. -- Bert |
#8 posted 275 days ago |
As CplSteel said, fit is easier to achieve. And remember, you ain’t gonna hit spec anyway. I’m not doing production work with metal. I’m doing hobby work with wood. I thickness the boards to 3/4” – on an August day that’s 98 degrees and 87% humidity. Then I have to work for a living; and my wife insists on visting people and having guests over and taking a trip and replantting the gardens; and I have to work for a living. When I finally get to cutting the tenons on the end of those boards, it’s almost Halloween and 45 degrees with 45% humidity – and I mis-measured when I thicknessed anyway – so damned if those boards aren’t 11/16ths thick! I try to keep my focus on making something that looks good and fits, not something that measures out exact. -- Jim Maher, Illinois |
#9 posted 275 days ago |
For my empathy.. I purchased a jet 6” jointer about 6 years ago. It was on sale and Rockler only had the floor model left. needless to say.. I will never buy the floor model again. The beds are not parallel, infact one has a slight bend to the bed as if it was dropped at some point. I was a naive to the tool at the time, but now I know more than I have ever wanted.. it is a great tool to have on hand.. but a total PITA to maintain and adjust. I moved on to make sleds for my table saw, but I still use it for pieces under 20”.. yet I still get angry at it and try to adjust it, shim it.. take it apart.. then give up! I only use it the best I can and move on with the desire to trash it and get a 8” grizzly or something. -- ~ Eric P Jorgenson: Jorgenson Design |
#10 posted 275 days ago |
I agree that changes in moisture can negate accuracy, particularly in humid climates like where I live. I also agree that woodworkers beat themselves up more than non woodworkers would care or notice in your projects. One thing I would say is that I don’t think it matters to have that level of accuracy over 6 feet or more. The weight of the wood would lay itself down if the ends of your infeed and outfeed are off a few thousandths. I’m sure if you planed a piece of wood (say 4 feet long or more) perfectly flat and uniform in thickness, then clamp one end to a bench and let it hang off, it would sag more than just a few thousandths. If you can get the 18” – 24” on either side of the cutting head to a flatness you find acceptable, then you should be able to produce stock reliably within your tolerances. If the machine has long feed tables then I would just check each for flatness and then flatness and accuracy between tables at the cutter head. If you use add-on feed extensions I would just get it close without going crazy. If you are spending more time lining up extensions than u did building them then it probably isn’t worth the time. -- "To do is to learn. A brilliant man once said that... I think he had a beard, too." - Joe Burns, HTML Goodies |
#11 posted 275 days ago |
If we were working with highly refined alloyed metals with controlled expansion / contraction rates, and building components intended for high speed operation I could see tolerances in the thousandths or ten thousandths being the range we want to work in, but we aren’t, we are working with wood, a media that moves and flows on its own. While I don’t encourage anyone to be sloppy in their work, I don’t see the point in going to extremes for accuracy when there is no real benefit. If for example a piece of steel stock used as a straight edge is within .001” in an 8’ run, to consider that not straight for woodworking purposes is for all intents and purposes over concern with accuracy. I would however be concerned if there was variation at the .1” per 8’ level… You say you have a 36” straight edge that is known good. You can check an 8 footer with your 3 footer. If 3 feet are good, then move down 2 feet so you are checking against a known good foot, and check, repeat until done… -- Manufacturer of fine quality sawdust since 1984. Comments and advice on my shop welcome. Check it out at http://lumberjocks.com/dbhost/workshop. Gladly accepting shop build donations! |
#12 posted 275 days ago |
I’ll add a couple thoughts…. In general, I think chasing thousandths in a woodshop can be misplaced effort. Because wood can be porous and has grain, variations of a few thou. are inherant to the material. Also, because wood “moves” a part that is spot on today, may not be tomorrow. But the human eye and sense of touch can detect differences as subtle as .005” quite easilly… so you want to have “perfectly” matching surfaces…. but how you get there with wood is a different approach… one that reflects more “craft” than it does “math”. So little things like the sequence in which you cut… making the final pass for all your table top boards through the planer at the same time, without and changes to the settings (so the part to part variation is effectively zero) is more important than the ability to dial in 1.000 on a Wixley. Woodworking craftsmenship has to take into account shrinking and swelling as well. So the better mortice and tennon joint isn’t necesarilly a 1.000” tennon in a 1.000” mortice. But rather, a slight interference fit achieved by lightly sanding a tennon that is intentionally cut slightly oversized untill it can be driven into the mortice, with relief cuts around the shoulder may yeild superior results. I certainly like precision… but I’m finding that the absolute measurements are of lesser importance than the relative measurements between mating parts.. -- Matt, Pine is fine, but Oak's no joke! |
#13 posted 275 days ago |
I think there is too much emphasis on making wood objects perfectly I know from experience my jointer doesn’t have to be perfect to A reliable thickness planer is more of an asset to me than a I recommend a 78” level as a most useful device for making A black lumber crayon and a white piece of chalk or grease |
#14 posted 275 days ago |
I have learned that as you gain experience, there are many times you don’t want a board to be perfectly straight. For example, gluing up a panel with tension in it will help it last for lifetimes without splitting. A jointer set to get a perfectly straight edge most likely will not do it on a regular basis and the board will more likely than not have a convex curve in it. I used to adjust mine so a very slight concave curve resulted. Another example, A bit of curve on a hand plane blade is useful to speed removal of rough surfaces and slight (<.002> concave edge for edge gluing. BTW I’m happy if a 10” blade wobbles less than .005. -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
#15 posted 275 days ago |
I think people try to be too precise when it comes to woodworking many times when it comes to perfect joints and what not, but when it comes to straight/square cuts – small differences do show up in the finished product and yes, it does make a difference. to a few thou in the finished cut? definitely not, but definitely to 1/64th. thats as far as cuts go, but when we discuss setting up machinery there is another aspect to it – safety. bear in mind – setting up machinery with precision is greatly different than using that machinery to cut wood precisely…. 2 different scales being used there. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
| Forum | Topics |
Woodworking Skill Share
8799 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15818 |
Hand Tools
2040 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
904 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6167 |
