Need installation instructions for Delta Unifence
Forum topic by usnret posted 274 days ago 980 views 0 times favorited 7 replies Add to Favorites Watch
View usnret's profile
usnret
185 posts in 678 days
274 days ago
Topic tags/keywords: question tablesaw unifence
I purchased a used Unifence for $100 its in pretty good shape. The problem is how do I install it. It is a really old model because it says “Rockwell Unifence”. The main head of the fence only has 2 adjustment screws that are for adjusting the fence parallel to the blade. The rail is the old style with the closed back with 4 holes drillied in it for mounting. Any help is appreciated.
-- Chief Petty Officer USN(RET) 1991-2011
7 replies so far
View Roger's profile
Roger
9191 posts in 974 days
#1 posted 273 days ago
I’d try doing a google search on an instruction manual
View JAGWAH's profile
JAGWAH
924 posts in 1254 days
#2 posted 273 days ago
Try googling for pictures of this fenc and saw. Sometimes in lieu of instructios a picture can give a direction.
-- ~Just A Guy With A Hammer~
View mrg's profile
mrg
483 posts in 1169 days
#3 posted 273 days ago
If I am correct bolt the rail to the front of the saw and put the fence on that’s it.
-- mrg
View RetiredCoastie's profile
RetiredCoastie
998 posts in 1353 days
#4 posted 273 days ago
You bolt the rail to the front of the table with bolts and nuts. The bolts go through the fence first, tape measure side against the table, align the bolts with the holes in the table edge and install the washers and nuts. Snug the bolts down but not tight. Install the rip fence and ensure the fence guide travels smooth. If it travels smooth tighten the rail hardware. Install the rip fence and check fence face for 90 deg to the table if not adjust leveling adjusters on top of fence guide until square. Adjust fence for square to miter slot by adjusting adjuster on front of the fence guide until fence is plum to slot. A dial indicator and an incinometer helps with setting this fence up but can be done with a good square and feller gauges. Before you begin all this ensure the table is square to the saw blade otherwise all of this is pointless.
If the holes in the fence don’t match up to the table, you can re-drill the rail to match up to your saws table existing holes, just make sure they are at the correct height along the fence.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
View tenontim's profile
tenontim
2129 posts in 1914 days
#5 posted 273 days ago
What the coastie said, but if you’re still having trouble with this, send me a PM with your mailing address, and I’ll get you some written instructions.
-- Tim-- http://www.tmuli.com
usnret
#6 posted 272 days ago
I mounted it on my old CRaftsman TS(from the 60’s). I just drilled out the mounting holes for the factory fence a little bigger and it lined up with the holes in the fence rail. Now I just have to make a table for it since it is a 52” fence. The installed tape didnt line up properly, it was off by a little over an inch so I will just buy a new stick on tape from Rockler and install it. Will post pics when get it fully installed with table.
View SweetHomeAlabama's profile
SweetHomeAlabama
1 post in 252 days
#7 posted 238 days ago
I just posted a pdf copy on http://vintagemachinery.org/ under Delta Manufacturing Company publications. The file is named “Delta Unifence Instruction Manual”. I hope this helps.
