Shaker Sideboard Front Apron Question
Forum topic by NewEnglandsWoodWorks posted 08-22-2012 02:07 AM 1405 views 0 times favorited 3 replies Add to Favorites Watch
View NewEnglandsWoodWorks's profile
117 posts in 2566 days
08-22-2012 02:07 AM
Topic tags/keywords: question shaker
Hi all,
I am in the middle of a build and I ran into a design feature that I had not thought about earlier. The table I am building is a simple sideboard table with two drawers n one apron. What would be the best way of cutting the areas out where the drawers will go. Jig saw? Ripping pieces out on the table saw and gluing it back together.
Let me know what everybody thinks.
-Brett
-- Brett
3 replies so far
View bruc101's profile
bruc101
1200 posts in 3507 days
#1 posted 08-22-2012 02:27 AM
If no one jumps in here with a drawing before I can pull up a CAD drawing of one I’ll post it for you in a little while. You don’t have to cut any openings out with a saw.
-- Bruce Free Plans http://plans.sawmillvalley.org
bruc101
#2 posted 08-22-2012 02:46 AM
Here is a single drawer Shaker style. Simple to add another drawer. Just add a center section of the frame the width you want to make your two openings work for you. Just cut your drawer dividers the length you need to make the openings and glue them to your face frames. Instead of having two center face frames you’ll have three to get two drawers.
View thebigvise's profile
thebigvise
191 posts in 2866 days
#3 posted 08-22-2012 02:55 AM
Make your apron about 1/2” longer and 1/2” wider than final dimension.
Rip twice so that the middle portion is the desired height of the drawer front. Then cross cut the ends of the middle portion to leave your with the desired width of the drawer front. Then glue the parts back together minus the drawer front. The extra 1/2 inch will cover the wood loss from the kerf.
-- Paul, Clinton, NC
