Replacement tool rest/tail stock lock lever
Forum topic by lumberjoe posted 08-21-2012 06:23 PM 4026 views 0 times favorited 4 replies Add to Favorites Watch
View lumberjoe's profile
lumberjoe
2899 posts in 2246 days
08-21-2012 06:23 PM
I love my HF lathe, however the tailstock and tool rest lock levers are plastic and won’t last – especially because my wife uses the lathe a lot and loves to REALLY hammer them down. Has anyone ever replaced them with metal ones? I built a fly tying vice with similar positionable lock levers from McMaster Carr a very long time ago. If I remember correctly it tool several weeks to get the parts. I looked up the Grizzly clone and it also has plastic lock levers.
Has anyone replaced these on either the HF or Grizzly lathe with replacements from Delta or JET?
View b2rtch's profile
b2rtch
4861 posts in 3046 days
#1 posted 08-21-2012 06:29 PM
Joe levers are you talking about?
The whole lever or just the handle?
On my lathe the handle is plastic but the lever is steel.
Another thing : tell your wife to go easy on the lath or better yet, let her break it and then have her buy a new and better one! ( Machiavelli, no?)
-- Bert
lumberjoe
#2 posted 08-21-2012 06:32 PM
The whole thing (except the screw) is plastic on my lathe. I should have specified. There are two levers on each – one lever locks the tail stock/tool rest to the bed. Those are metal and fine. The lever that locks the height/position of the tool rest is plastic. The lever that locks the quill on the tail stock is the same and also plastic. Those are the ones I am looking to replace.
lumberjoe
#3 posted 08-21-2012 06:45 PM
Bert – I’ve got my eye on a new lathe already. My wife is completely obsessed with this thing! It’s literally all she does and talks about. I can barely get to use it. I’m going to post some of her stuff in a few. I’m looking to get a gently used lathe – either a Powermatic, Delta, or Jet with a much larger swing and more power so I can start doing bowls. I’ll set up the HF lathe in a different spot just for her. I’m also considering buying another small table saw and making a cross cut sled for her so she doesn’t need to keep using mine. I don’t like anyone else touching my table saw.
View bondogaposis's profile
bondogaposis
4727 posts in 2349 days
#4 posted 08-21-2012 07:02 PM
Reid Supply has a lot of that type thing, you might want check there.
-- Bondo Gaposis
