Nice rounded edges
Forum topic by RussellAP posted 08-20-2012 04:40 PM 2746 views 0 times favorited 3 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2249 days
08-20-2012 04:40 PM
Most woodworkers will use a router to smooth the edge off of a board. That’s fine if you have the router conveniently placed and ready to go in the shop and you like extra work. But something just as good is to sand the edges with a vibrating sander with some 60 grit. It’ll take the edge off most woods, soft wood is better of course, but it rounds the edges off nicely and is pretty easy to control. I figure if I’m there sanding the board, I may as well round off the edges while I’m there. I wouldn’t try it with a ROS unless you’re practiced with it.
Sanding won’t take off as much material nor round-over as uniformly as a router will, however when using soft woods like pine or cedar, the router can easily mar a board especially if there is a knot on the edge. Sanding will take the risk out of this.
I use the Black & Decker Mouse to do this. Just make sure to go over the straight surfaces with the ROS when you are finished because the Mouse will leave scratches on the face of the board and you may not see them till you finish the piece.
Give this a try next time and see if it saves you some time.
3 replies so far
View Loren's profile
10244 posts in 3611 days
#1 posted 08-20-2012 05:01 PM
You can try running a round over router bit with a fence instead
of a bearing, too. If the board has machine marks in the side
the bearing-guided bit will follow the marks and the roundover
looks squiggley and badly machined. With the fence instead
the roundover line is made straight. You have to go back and
sand it though, because the profile won’t be totally consistent,
so in combination with the power sanding method, the roundover
bit in a router with the fence is a time saver in not-so-fine work.
I have several 1/4” yard sale routers and I’ll leave them set up
for one cut like this. The fence can be just a block of wood
screwed to the router base with a cutout for the bit.
View tenontim's profile
tenontim
2131 posts in 3707 days
#2 posted 08-20-2012 11:01 PM
I have a chamfer and a round over plane that I use regularly for this chore.
View Bernie's profile
Bernie
422 posts in 2800 days
#3 posted 08-21-2012 03:04 AM
A nicely sharpened cabinet scraper – works great for me and fun to use.
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
