Grizzly 17" band saw and Shop Fox mobile base
Forum topic by JesseTutt posted 08-20-2012 04:15 PM 2448 views 0 times favorited 2 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2105 days
08-20-2012 04:15 PM
Topic tags/keywords: bandsaw grizzly shop fox question
I am planning to buy either the Grizzly G0513×2b or G051×2bf. Both list the size of the base as 27” x 17 3/4”. Grizzly sells a mobile base made by Shop Fox that lists its size range as 20” x 20” to 29” by 29”. Since I happen to already have this Shop Fox base I plan to use mine.
But if the base is 27×17 3/4 how does it fit on a 20” x 20 base?
I recall reading somewhere that you needed to use plywood on the base. I don’t recall if they were talking about the Shop Fox base.
2 replies so far
View redryder's profile
redryder
2393 posts in 3096 days
#1 posted 08-20-2012 06:27 PM
You won’t have any trouble fitting the base you have to the band saw you want. The base is adjustable and snugs down with bolts.
The headache you will have is getting that beast on the base.
Good luck…................
-- mike...............
View Surfside's profile
Surfside
3389 posts in 2168 days
#2 posted 08-20-2012 08:33 PM
The base fits. Cool!
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
