Question about V-Belts
Forum topic by b2rtch posted 08-19-2012 09:38 PM 1709 views 0 times favorited 10 replies Add to Favorites Watch
View b2rtch's profile
b2rtch
4868 posts in 3284 days
08-19-2012 09:38 PM
Topic tags/keywords: question jointer
As some of you know I just finish rebuilding a Powermatic 60 jointer.
I installed a new 3 HP motor and I am using the original 2V-Belts pulleys with 2 new twist belts.
It seems that I had to re-tension the belts every day, which tells that I probably exceeded the belts power/torque transmission ability.
I also have a Unisaw with a 3HP motor and it uses three of the same twist belts.
I never yet had to re-tension the belts.
I looked on line for some kind of table indicating the maximum power/torque for V-belts but except for some very technical stuff, I could not find any information.
Interestingly enough on the parts catalog for the new Powermatic 60 with a 3HP motor there is only one belts.
I suppose they use one of this new multi-rib/serpentine belt.
It seems time that I am going to have to replace the pulley with 3 grooves pulleys to accept a third twist belt or may install multi-rib pulleys and belt.
What do you think?
-- Bert
10 replies so far
View oluf's profile
oluf
260 posts in 3275 days
#1 posted 08-19-2012 11:27 PM
You can get great advise and quality products here, Thier prices are also veyr good. VBeltSupply.com thier toll free number is 1 888 291 5450 and a belt expert will awnser the telephone.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
b2rtch
#2 posted 08-19-2012 11:28 PM
oluf, thanks
-- Bert
View Dusty56's profile
Dusty56
11830 posts in 3924 days
#3 posted 08-19-2012 11:35 PM
Hi Bert , my ‘50’s vintage Powermatic 60 only has one V pulley and belt. Have you run the jointer for any period of time to let the belts settle in / stretch out / find their groove ? LOL
Is it just the weight of the motor applying tension to the belt(s) ?
View rance's profile
rance
4267 posts in 3396 days
#4 posted 08-19-2012 11:52 PM
I think your tensioner(or motor mount) is slipping.
Dusty56
#5 posted 08-20-2012 12:03 AM
Bert , your headline is about V-belts and your post is about Twist-belts…what’s the story ?
Are you referring to Link-Belts , such as the Red or Green ones ?
View MrUnix's profile
MrUnix
7106 posts in 2435 days
#6 posted 08-20-2012 12:18 AM
I’ve had good success with kevlar belts which have very low stretch and high durability.
b2rtch
#7 posted 08-20-2012 12:20 AM
” Are you referring to Link-Belts , such as the Red or Green ones ?”
Yes, I use the HF one.
I do not think that my adjuster is slipping as I use 4×5/16 cap screws and I make sure to torque them real good.
I believe that the belts are stretching.
-- Bert
Dusty56
#8 posted 08-20-2012 12:52 AM
Hi Bert , I have used the HF belts as well and had to run my machines for a while to let them settle into place.
My machines just had the weight of the motor tensioning the belts though. Do you have the belts running in the right direction ?
View ChuckV's profile
ChuckV
3183 posts in 3763 days
#9 posted 08-20-2012 01:49 AM
Bert,
The installation instructions for Power Twist belts (http://www.fennerdrives.com/assets/ptpinstall.pdf) says this:
VI. Retensioning
Like all high performance V-belts, PowerTwist Plus V-Belts require the maintenance of correct
drive tension to operate efficiently. Experience indicates that drive tension should be checked after
24 hours running at full load. A retension may be necessary depending on the severity of the drive.
Any initial belt stretch is then taken up. Subsequently, belt tension should be checked periodically
and adjusted when necessary.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
b2rtch
#10 posted 08-20-2012 09:52 AM
“Do you have the belts running in the right direction ? ” and what is the right direction?
At one time I read that there are arrows on the belts, indicating the rotation.
I never could see one.
Thank you Chuck, I shall spend sometime this site to checking the instruction
-- Bert
