The right sander for the job
Forum topic by Richard posted 08-19-2012 07:23 PM 1101 views 0 times favorited 9 replies Add to Favorites Watch
View Richard's profile
Richard
113 posts in 3652 days
08-19-2012 07:23 PM
Topic tags/keywords: sander drill press
I am making a coffee with an odd shape. No straight lines in the top. I rough cut the top with a jigsaw and now I need to take off the last quarter inch to bring it down to final size and shape. All the curves are outside curves. I would use a router but I can’t set up any straight edges as guides and I don’t trust my jittery hands to do it free-hand. I was thinking a spindle sander would be the best rout. I have a combo disk\belt sander. I also have a small drum sander kit to put on my drill press. I am tempted to try to use what I have but was wondering about safety and putting directional pressures on tools the were not ment to be. Any thoughts would be appreciated.
9 replies so far
View Bill White's profile
Bill White
5148 posts in 4197 days
#1 posted 08-19-2012 07:28 PM
There are those who will caution about using sanding drums on a drill press because of side-loading the quill bearings. I have done it, but now have an OSS (Ridgid).
Just my thoughts.
Bill
-- bill@magraphics.us
View oluf's profile
oluf
260 posts in 3275 days
#2 posted 08-19-2012 11:35 PM
Use your sanding drums in a hand drill and keep them moving up and down as you sand. This is only if you do not have an OSS or the top is too heavy to handle on the OSS work surface.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View jmos's profile
jmos
905 posts in 2606 days
#3 posted 08-19-2012 11:44 PM
Spokeshaves and rasps will remove a lot of material quickly, and with a heck of a lot less dust than sanding. I would prefer to shape with them and sand for a final finish.
-- John
View rance's profile
rance
4267 posts in 3397 days
#4 posted 08-19-2012 11:49 PM
I would not be as concerned with messing up the bearings. I’d say you are more likely to have the drum work loose from the Jacobs chuck and possibly get thrown across the shop. A bearing on the lower part of the drum(at the table) would take care of that though.
And +1 to what John said. Although I’d go find a power tool version. :D
Richard
#5 posted 08-20-2012 12:00 AM
Thanks for the reply’s everyone. My cheap side says use what I got and modify it. In the back of my mind I was wondering if there was a hand tool that was better for the job. I need to remove about a 1/4 inch from the edge of the table top that is 3/4 inch thick. Is a spoke-shave best for this application or perhaps some other plane?
rance
#6 posted 08-20-2012 12:05 AM
Or a hand-held belt sander with 36 grit paper. Seriously. So why did you not get any closer than 1/4”? It would make your next process easier.
Richard
#7 posted 08-20-2012 12:09 AM
Well it actually varies. most places are probably more like an eighth inch. I was using a jigsaw so I was worried about tear-out. Not to mention my unsteady hand.
View teejk's profile
teejk
1215 posts in 2921 days
#8 posted 08-20-2012 12:31 AM
First I would lay a strip of blue painter’s tape on the field to define the finished dimensions. Then use whatever you have to get closer (without touching the tape).
From there, any tool with a flat table perpendicular to the tool should work to get to the tape edge. I personally have problems with hand helds (belt sanders etc) in keeping perpendicular to the top. Maybe it’s just me.
View jmos's profile
jmos
#9 posted 08-20-2012 01:03 PM
A lot depends on the type of curve, you can use a block plane, if the blade will contact the curve as you go around (trying to avoid talking convex and concave to avoid confusion). A spokeshave will work on either type curve (there are different types of shaves, a flat base will work similar to the block plane, a curved base shave is better for an ‘inside’ curve), a rough rasp will do either type of curve and can hog off some material (follow up with finer rasps or sanding to smooth the surface left by the rasp), a drawaknife can work well too.
Card scrapers work nicely for doing some fine shaping and finishing off the edge.
If you want to go power, you can make a template out of thinner material (hardboard or thin plywood) and use a template following bit on your router. Fix the template to the work with clamps or double sided tape. If you use the same template for opposite sides of the piece it will ensure symmetry (assuming that’s what you are going for).
Yup, a belt sander with a low grit will hog some material too, but noisy and dusty.
Spindle sander will certainly work too. I lean toward other methods when I can, but if it works, and you have the tools, it’s a good option too.
-- John
