Used Jointer: Bargain or No?
Forum topic by DylanC posted 272 days ago 879 views 0 times favorited 16 replies Add to Favorites Watch
View DylanC's profile
DylanC
82 posts in 840 days
272 days ago
Found a older (1972?) Craftsman 6” jointer with stand at a local flea market. Model is a 113.20650. Guy is asking $90. Cast iron looks to be in good shape with just some minor surface rust. See the pic and let me know what you think. It looks like bearings and knives are still available from Sears.
I’ll probably go back tomorrow and check out the bits and pieces a bit better (table/fence adjustment, etc.). Probably see if I can plug it in and start it up, too. Any other things I should look for?
-- Dylan C ...Seems like all ever I make is sawdust...
16 replies so far
View knotscott's profile
knotscott
4180 posts in 1541 days
#1 posted 272 days ago
That’d be worth $90 IMO….you can always offer less.
View jim C's profile
jim C
1400 posts in 1264 days
#2 posted 272 days ago
If it runs and you can still get parts for it, I would grab it in a heartbeat. Made in U.S.A. and cast iron! Just be advised it will probably be a useful tool as long as it’s set up properly with regard to perpendicularity, blade concentricity etc.
-- Government does not solve problems; it subsidizes them.
View waho6o9's profile
waho6o9
2878 posts in 742 days
#3 posted 272 days ago
http://minneapolis.craigslist.org/ank/for/3211669657.html
Here ya go for 75.00, some what similar. HTH
Craftsman on the lake
2019 posts in 1603 days
#4 posted 272 days ago
I’ve got one slightly newer than that but it looks pretty much the same. It’s what I use in my shop and it works fine. Turn it on and make sure the bearings appear to run smoothly.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://gagnerwebsite.com/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
DylanC
#5 posted 272 days ago
I did a bit of browsing online and even a new 4” craftsman or 6” Grizzly is $230 and probably not nearly as solid. I’m thinking I’ll offer $75, but if the adjustments and bearings are good it’s worth the full $90.
View MrUnix's profile
MrUnix
256 posts in 364 days
#6 posted 272 days ago
Those are selling around here in good working order in the $50-$75 range so I’d offer less than what they are asking. If you get it, don’t buy the bearings/blades from sears.. the bearings IIRC are standard 6202-5/8’s and the blades are fairly common 6-1/8×11/16×1/8. Both can be found on-line for about $20.
-- Brad in FL - To be old and wise, you must first be young and stupid
86927 posts in 1742 days
#7 posted 272 days ago
$125 max and $45 it’s a steel. if it work properly.
View Loren's profile
4865 posts in 1813 days
#8 posted 272 days ago
Machine looks clean. Worth $50-$100. Those are decent
jointers. That style has gone out of popularity because
people these days want longer tables, bit there’s nothing
wrong with a short-bed jointer and if you need to you can
make extension tables for longer work.
View Tedstor's profile
Tedstor
924 posts in 798 days
#9 posted 272 days ago
I’d buy it. I have an even older 4” Craftsman jointer. Works great. I’ll probably upgrade to a 6” in the near future. I see them fairly often for anywhere between $50-$250. Of course, anything over $150 is a seller that is clearly dillusional or completely ignorant to the value of 30+ year-old crafty jointers.
As mentioned, don’t buy parts from Sears. I bought new bearings for my jointer from Sears ONLY because I thought I was more likely to get the correct part. I feared an aftermarket supplier would send me ill-fitting or inadequete parts. I paid twice the price for this peace of mind and to lessen my chances of getting jerked around. What did I get?
A box arrived 9 days later (an eternity in the modern era), with ONE bearing and a packing slip that said “the remainder of your order is not in stock. We will automatically fill your order when new stock arrives in 30-60 days.
Sears CS did nothing to satisfactorily remedy the situation. I asked that they pay the return shipping and canccel the order. They told me the part was non-returnable but did agree to cancel the remainder of the order.
I then ordered the bearings from an aftermarket supplier. They arrived three days later and fit/work great.
View Dusty56's profile (online now)
Dusty56
10496 posts in 1853 days
#10 posted 271 days ago
Buy the jointer , after market bearings and knives are very inexpensive : )
I can actually buy new knives for what it costs to sharpen my dull ones…sometimes less : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
Beginningwoodworker
13225 posts in 1838 days
#11 posted 271 days ago
I would buy it , those are great jointers.
-- CJIII Future cabinetmaker
DylanC
#12 posted 271 days ago
Well, I bought it…for just a bit less than the asking price. Got home, plugged it in and fired it up. Runs pretty well except for a bit of vibration from the belt “memory”. Might replace it with one of those fancy link belts. Other than that the only required work will be to clean up the table and fence and get the blades sharpened or replaced. The cord and switch could also be replaced, but they work as-is.
Thanks for all the great advice and I’ll post a few photos for the blog when I get ‘er all prettied up.
Dusty56
#13 posted 271 days ago
Congratulations !!
View thedude50's profile
thedude50
3316 posts in 643 days
#14 posted 271 days ago
Nice score way to go
-- when I am not on Lumberjocks I am on @ http://thisoldworkshop.com where we allow free speech
View quartrsawn's profile
quartrsawn
110 posts in 1378 days
#15 posted 271 days ago
Thats a nice Caftsman style chair next to it, just saying.
-- Nat - West Sayville,L.I., NY
